Hi Jeff,
I'm afraid to say that even your latest commits don't fix this. Same
place, same error.
Perhaps you should really install a few different gcc versions on your
box for testing.
Ralph
>>>>> "Jeff" == Jeff Hill <[email protected]> writes:
> Ralph,
> Was this problem occurring with R3.14.Beta2? I guess not. Based on
> that guess and on C++ compiler conformance reports on the web I am
> concluding that gcc 2.95.x does not support C++ throw specifications.
> I adjusted libCom/misc/cxxCompilerDependancies.h accordingly and
> committed the change. Be sure to let me know if this does not take
> care of your problem. If necessary I will install gcc 2.95 into one
> of our Linux systems to test further. Do you know if it's safe to
> use a gcc version on Linux which significantly varies from the gcc
> version that was used to build the Linux kernel?
> Jeff
>> -----Original Message-----
>> From: Ralph Lange [mailto:[email protected]]
>> Sent: Monday, November 04, 2002 2:07 AM
>> To: Jeff Hill
>> Cc: Bob Dalesio; Andrew Johnson; Kay-Uwe Kasemir;
> [email protected];
>> Marty Kraimer; [email protected]
>> Subject: Your commits (cont'd)
>> >>>>> "Ralph" == Ralph Lange <[email protected]> writes:
>> > Hi Jeff,
>> > when I'm compiling your latest commits on my Linux box (RedHat 7.1
>> with
>> > g++ 2.95.3) I get
>> > /opt/gcc/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>> DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -
>> Dlinux -D_REENTRANT -ansi -pedantic -O3 -Wall -mcpu=pentium -
>> fPIC -I. -I.. -I../../../include/os/Linux -
>> I../../../include ../cac.cpp
>> > In file included from ../virtualCircuit.h:35,
>> > from ../cac.cpp:37:
>> > ../comQueSend.h: In method `void
> comQueSend::push<ca_uint16_t>(const
>> ca_uint16_t &)':
>> > ../comQueSend.h:145: instantiated from here
>> > ../comQueSend.h:123: Internal compiler error.
>> > ../comQueSend.h:123: Please submit a full bug report.
>> > ../comQueSend.h:123: See
>> <URL:http://www.gnu.org/software/gcc/bugs.html> for instructions.
>> > make[3]: *** [cac.o] Error 1
>> Hm.
>> Same error using gcc 2.95.4.
>> The RedHat original (yuck) so-called gcc 2.96 works.
>> Version 3 gcc seems to work, too.
>> What should we do? Which gcc versions are we officially supporting?
>> (Didn't find anything on the EPICS web.)
>> Cheers,
>> Ralph
__ Ralph Lange [email protected]
/\ \ http://www.bessy.de/~lange
/ \ \ BESSY II
/ /\ \ \ Berliner Elektronenspeicherring- Albert-Einstein-Str. 15
/ / /\ \ \ Gesellschaft fuer Synchrotron- 12489 Berlin, Germany
/ / /__\_\ \ strahlung m.b.H.
/ / /________\ Phone: +49 30 6392-4862
\/___________/ Control System Group Fax: ... -4859
- RE: Your commits (cont'd) Ralph Lange
<2002>
2025
2026
<2002>
2025
2026
