Jeff,
> Was this problem occurring with R3.14.Beta2? I guess not.
I used the term "your latest commits" to describe the moment when these
errors occurred first.
> [...] If necessary I will install gcc 2.95 into one of our Linux
> systems to test further. Do you know if it's safe to use a gcc
> version on Linux which significantly varies from the gcc version
> that was used to build the Linux kernel?
The only problem is the mysterious 2.96 that RedHat shipped with their
distribution < 8.0 (now they're using gcc 3), which is based on an
unofficial snapshot from GNU that was never meant to be released plus
further bugfixes by RedHat.
The RedHat version's c++ name mangling is incompatible with any gcc 2 as
well as with any gcc 3. So you cannot use _static_ RedHat system
libraries for linking code produced by any other compiler version.
Shared libs / dynamically linked binaries are working without any
problems. I'm using 2.95.3 on my RedHat system for anything except
kernel compilation since ever without any failure.
Actually, I installed a variety of gcc versions on my RedHat box, put
them all in /opt/gcc-<version> directories and can easily switch by
setting the GNU_DIR in the configure files. Just build the gcc from
sources with "./configure --prefix=/opt/gcc-<version" and make/install.
You will also need to build a recent version of the binutils package and
re-install it (using the same configure command line) into every of
these gcc directories. Re-installing will do - no need to recompile.
That's it. (You may need to update /etc/ld.so.conf and 'ldconfig'.)
Ralph
>> -----Original Message-----
>> From: Ralph Lange [mailto:[email protected]]
>> Sent: Monday, November 04, 2002 2:07 AM
>> To: Jeff Hill
>> Cc: Bob Dalesio; Andrew Johnson; Kay-Uwe Kasemir;
> [email protected];
>> Marty Kraimer; [email protected]
>> Subject: Your commits (cont'd)
>> >>>>> "Ralph" == Ralph Lange <[email protected]> writes:
>> > Hi Jeff,
>> > when I'm compiling your latest commits on my Linux box (RedHat 7.1
>> with
>> > g++ 2.95.3) I get
>> > /opt/gcc/bin/g++ -c -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
>> DOSITHREAD_USE_DEFAULT_STACK -D_X86_ -DUNIX -D_BSD_SOURCE -
>> Dlinux -D_REENTRANT -ansi -pedantic -O3 -Wall -mcpu=pentium -
>> fPIC -I. -I.. -I../../../include/os/Linux -
>> I../../../include ../cac.cpp
>> > In file included from ../virtualCircuit.h:35,
>> > from ../cac.cpp:37:
>> > ../comQueSend.h: In method `void
> comQueSend::push<ca_uint16_t>(const
>> ca_uint16_t &)':
>> > ../comQueSend.h:145: instantiated from here
>> > ../comQueSend.h:123: Internal compiler error.
>> > ../comQueSend.h:123: Please submit a full bug report.
>> > ../comQueSend.h:123: See
>> <URL:http://www.gnu.org/software/gcc/bugs.html> for instructions.
>> > make[3]: *** [cac.o] Error 1
>> Hm.
>> Same error using gcc 2.95.4.
>> The RedHat original (yuck) so-called gcc 2.96 works.
>> Version 3 gcc seems to work, too.
>> What should we do? Which gcc versions are we officially supporting?
>> (Didn't find anything on the EPICS web.)
>> Cheers,
>> Ralph
Re: Next Release Andrew Johnson
RE: Your commits (cont'd) Ralph Lange
<2002>
2025
2026
<2002>
2025
2026
