Here's yet another idea how the runaway-task problem could be solved.
AFAIK, most OS provide a hook into the system timer ISR but not
into the console ISR [which makes what we discussed at JLAB less
portable] - these hooks are vxWorks' watchdog timers, RTEMS' rtems_timers.
1) The shell task periodically resets (pets) a 'watchdog' counter.
2) A timer ISR increments 'watchdog'. Should 'watchdog' reach a critical
'limit', this implies that the shell had no chance to pet.
In this case, the ISR increments the task's priority and resets
'watchdog'.
If a task with a priority > shell runs away, 2) will eventually raise
the shell's priority above the runaway task's and the user will regain
control.
-- Till
- Re: base max thread priority Eric Norum
- RE: base max thread priority Jeff Hill
Re: base max thread priority Till Straumann
<2002>
2025
2026
<2002>
2025
2026
