<20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: base max thread priority
To: Till Straumann <[email protected]>
Cc: Marty Kraimer <[email protected]>, "Johnson, Andrew N." <[email protected]>, Jeff Hill <[email protected]>
Date: Tue, 26 Nov 2002 20:35:01 -0600
On Tuesday, November 26, 2002, at 04:49  PM, Till Straumann wrote:
Hmm - a very good point. There might also be other RTEMS system/driver tasks. I'm just wondering whether confining the epics accessible priority range to a subrange of the RTEMS/vxWorks priorities is a good solution? Having this restriction, a RT critical task may still not be able to use the EPICS OSI thread API to obtain the priority it needs...
BTW - Eric, I believe that the RTEMS interrupt message logger also runs
at the highest EPICS priority which is probably not really necessary.
O.K.  What names should be added to epicsThead.h?
static const unsigned epicsThreadPriorityIocsh = 91;
static const unsigned epicsThreadPriorityNetwork = 91;
static const unsigned epicsThreadPriorityBaseMax = 91; <<< base-max, jumbo-shrimp??? >>>
Eric Norum <[email protected]>
Department of Electrical Engineering
University of Saskatchewan
Saskatoon, Canada.
Phone: (306) 966-5394   FAX:   (306) 966-5407
Re: base max thread priority Till Straumann
Prev: Re: base max thread priority Till Straumann
Next: Re: base max thread priority Eric Norum
Index: <20022003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: base max thread priority Jeff Hill
