Benjamin Franksen wrote:
On Friday 18 February 2005 18:12, you wrote:
I have again updated dbd.html which is available via
http://www.aps.anl.gov/asd/people/mrk/epics/base/V4
Hi Marty,
one comment regarding the epicsTypes document and a proposal for an additional
structured data type.
First, I don't understand why every library is specified as as a structure of
function pointers ("interface"). IMO, this only makes sense if you anticipate
the interface to be passed as an argument, because there might be different
implementations of the same interface. If all you ever use is one and the
same global pXYZInterface, then all this gives you is the run-time overhead
caused by the additional level of indirection.
One reason is that the epicsShare nightmare almost goes away. Instead of
epicsShareFunc <type> epicsShareAPI xxxFunc(...
for every function in a library . By using an interface there is just
one definition such as
epicsShareExtern asynManager *pasynManager;
Another reason is "Everything is an interface" seems like a good idea.
Note that most interfaces will have multiple implementations just like
for asynDriver.
A comment about using C++ instead of C. This could all be done in C++
using pure abstract classes. But when I think about the syntax, the C++
version looks worse (at least to me) than the C version with one exception.
C forces the definition
typedef struct <someInterface> {
<type> (*method)(<args>);
Rather than
<type> method(<args>);
Other than that the C++ syntax is more verbose than C.
Second point. As a more general observation, much of what I read in the above
documents reminds me of inventing yet another (domain specific) programming
language. Only that it is not for programming, but restricted to data
specification (no way to define functions or routines). The latter is
expected to be done in a separate language (C, sometimes SNL). Although the
data model is strongly influenced by what is available in C, it is still hard
to come up with good generic routines to handle this data in C. This is no
wonder, given that C is not very powerful when it comes to genericity.
But I digress. What I want to point out is that there is one very useful thing
missing from the data model, namely algebraic data types, a.k.a. tagged
unions. A syntax could look like this
union(name) {
choice(choice_name,"choice_value",choice_data)
where 'choice_data' can be any valid data type, including struct or another
union. Thus, menu would be the special case where the 'choice_data' is void
(or null; another basic data type to be added).
Let me give an example where I missed the possibility to define such a data
type: When lately I wrote a general conversion record, I would have liked to
define something similar to the following:
union(convSpec) {
choice(convLinear,"Linear",linearConvSpec)
choice(conv1DTable,"1D Table",tableConvSpec)
choice(conv2DTable,"2D Table",tableConvSpec)
choice(convSubroutine,"Subroutine",subroutineConvSpec)
struct(linearConvSpec) {
field(offset,DBF_DOUBLE)
field(slope,DBF_DOUBLE)
struct(tableConvSpec) {
field(name,DBF_STRING)
field(directory,DBF_STRING)
struct(subroutineConvSpec) {
Even with your extended V4 dbd language I could not do this, but had to split
the conversion specification to many fields. This raises many problems, for
instance: since there is no atomic update(*) of the whole conversion spec,
when is the update complete and to be acted upon? No way to know, other than
introduce yet another field as a trigger. Record support code becomes
unnecessarily complicated. Furthermore, each specification field must be
duplicated, in order to save the current values while new values are in the
process of being set. Etc. etc.
Andrew also suggested a union.
JAVA does not have a union. Will this cause us any problems?
Marty
Cheers,
Ben
(*) I understand that EPICS V4 will provide some method to atomically update
structured record fields.
- Re: EPICS base V4: iocCore database Benjamin Franksen
- Re: EPICS base V4: iocCore database Marty Kraimer
<2005>
2025
2026
<2005>
2025
2026
