On Tuesday 01 March 2005 17:30, Jeff Hill wrote:
> This c_str() function appears to be in mainstream use.
> Therefore, my conclusion has been that it will be very unlikely
> that an implemtation will exist with storage for non-contiguous
> fixed sized blocks and also storage for a continuous block that
> is a copy of what is in the non-contiguous blocks. This would of
> course double memory requirments and negate any benefits derived
> from bothering with non-contiguous fixed sized blocks in the
> first place.
The idea is, of course, that memory for the C string would be allocated as
soon as c_str is called, not earlier, and that teh user code is responsible
for freeing that memory.
> > /Any/ implementation of strings based on non-contiguous blocks
> > will encounter the same problem, if it wants to provide a
> > routine
> > to interface with routines that expect a contiguous
> > null-terminated
> > C string.
> Yes, and therefore an interface allowing non-contiguous
> implementations can not include such a function. A better
> alternative would be a function that copies the string to a user
> supplied contiguous buffer.
I agree that it would be clearer then whose responsibility it is to
allocate/free the memory (the user's), instead of spreading it between
std::string (allocation) and user (de-allocation). OTOH, such an interface
would be more vulnerable to buffer overflow errors.
The main point, however, is that you cannot solve the underlying problem by
refusing to provide method c_str. Either the functionality is not really
needed. In this case it would be sufficient to (strongly) discourage use of
this method and to point out its inefficiency.
Or, as you seem to suggest, users really /need/ this functionality i.e.
there /is/ lots of code that expects a classic contiguous C string (for
instance, because many old-style C string routines are used). In that
case /any/ implementation based on non-contiguous storage has the same
problem, regardless of the interface, and regardless of who (user or string
class) does the work of allocating additional storage and copying the data.
An advantage of providing c_str is that allocation and copying can be avoided
in cases where the string is short enough to fit into a single (fixed-size)
block.
> BTW: Functions like c_str are also a real problem from a thread
> safe interface perspective.
Why?
> Note however that the pure virtual string interface in data
> access exists to provide us options. We may use almost any string
> implementation we would like. This includes standard library
> strings and standard library streams should they be found to be
> suitable for a particular application.
Of course, the smaller your interface, the larger the set of possible
implementations that can be fit unto it. Or so it would seem.
Unfortunately, however versatile your string interface may be, it imposes an
imperative style on the implementation: it completely precludes functional
style (immutable) strings. Such strings are *so* much easier to handle, than
the traditional mutable ones. Take concatenation as an example. Functional
style:
res = concat(s1,s2);
Imperative style:
res = new string( s1.length() + s2.length() ); // or was it -1 or +1 ???
res.copy( s1 );
res.append( s2 );
Note that concatenation is probably _the_ most used standard operation on
strings (or rather, would be if it were not prohibitively expensive and
unwieldy in C).
In my experience, overwriting an already existing string is almost never a
natural solution to the problem at hand, but done only to avoid memory
allocation or copying.
An implementation based on non-contiguous storage, could take advantage of its
storage model, and almost completely avoid copying (at the cost of slightly
increasing the overall memory footprint). For instance, functional
concatenation can be done in constant time (avoiding all allocation and
copying). As long as strings are immutable and references are properly
tracked, an implementation can easily share the storage between different
strings (except the meta data). I would bet that such an implementation is in
the end a lot more efficient than any implementation based on mutability,
such as imposed by the dataAccess string interface.
Just my 2c.
Ben
- Re: memory management Andrew Johnson
- Re: memory management Benjamin Franksen
- RE: memory management Jeff Hill
<2005>
2025
2026
<2005>
2025
2026
