2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: memory management
To: Jeff Hill <[email protected]>
Cc: 'Eric Norum' <[email protected]>, 'Ralph Lange' <[email protected]>, 'Matej Sekoranja' <[email protected]>, 'Marty Kraimer' <[email protected]>, 'Andrew Johnson' <[email protected]>, 'Ken Evans' <[email protected]>, 'Bob Dalesio' <[email protected]>, "'Kasemir, Kay'" <[email protected]>
Date: Wed, 02 Mar 2005 13:34:15 +0100
On Wednesday 02 March 2005 01:54, Benjamin Franksen wrote:
> An implementation based on non-contiguous storage, could take
> advantage of its storage model, and almost completely avoid copying
> (at the cost of slightly increasing the overall memory footprint).
> For instance, functional concatenation can be done in constant time
> (avoiding all allocation and copying). As long as strings are
> immutable and references are properly tracked, an implementation can
> easily share the storage between different strings (except the meta
> data). I would bet that such an implementation is in the end a lot
> more efficient than any implementation based on mutability, such as
> imposed by the dataAccess string interface.
Another advantage of functional/immutable strings is that support for
unicode encodings is a lot easier and less error-prone. For instance,
since a UTF-8 character may be longer than one byte, a UTF-8 encoded
string should never be written to at an arbitrary byte index. With
immutable strings it is much easier to maintain such invariants.
The burden, in this case, would be with string analyzing functions such
as a generic 'split' function that turns a string into a pair
(front,back) of strings according to some character or substring
predicate that determines the split position. Note that such a function
would need to traverse the string character by character anyway (to
find teh split position). Thus, observing UTF-8 character boundaries
would cause almost no additional overhead.
Ben
RE: memory management Jeff Hill
Re: memory management Benjamin Franksen
Prev: Re: memory management Andrew Johnson
Next: RE: memory management Jeff Hill
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: string implementations (was: memory management) Benjamin Franksen
