2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: memory management
To: 'Andrew Johnson' <[email protected]>, 'Benjamin Franksen' <[email protected]>
Cc: 'Eric Norum' <[email protected]>, 'Ralph Lange' <[email protected]>, 'Matej Sekoranja' <[email protected]>, 'Marty Kraimer' <[email protected]>, 'Ken Evans' <[email protected]>, 'Bob Dalesio' <[email protected]>, "'Kasemir, Kay'" <[email protected]>
Date: Wed, 02 Mar 2005 10:47:27 -0700
> This means that the user code is *not* responsible for freeing
the
> memory, but the string library may do so itself when the next
string
> function is called that could change that string.
I have read similar things also.
> There *are* implementations of the C++ std::string API that use
> non-contiguous blocks
I can see that this would be possible, but they will of course
need to allocate a contiguous block and copy into it when c_str
is called, and we are full circle to the original premise which
was that the c_str() interface does not permit an implementation
based exclusively on memory management employing non-contiguous
fixed sized blocks.
Assuming that disembowelment of the basic_string supplied with
the default standard library in favor of an alternative
implementation was an approach we wanted to employ then admitedly
we need only be an unusually well disciplined code base, choosing
not to call the c_str() function, in order to reach fixed sized
non-contiguous nervana 8-)
Jeff
Re: memory management Andrew Johnson
Prev: Re: memory management Benjamin Franksen
Next: RE: memory management Jeff Hill
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: memory management Andrew Johnson
Next: string implementations (was: memory management) Benjamin Franksen
