2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: memory management
To: Jeff Hill <[email protected]>
Cc: 'Bob Dalesio' <[email protected]>, 'Ralph Lange' <[email protected]>, 'Andrew Johnson' <[email protected]>, 'Matej Sekoranja' <[email protected]>, 'Ken Evans' <[email protected]>, 'Benjamin Franksen' <[email protected]>, 'Eric Norum' <[email protected]>, 'Marty Kraimer' <[email protected]>
Date: Wed, 02 Mar 2005 15:13:54 -0500
On Mar 2, 2005, at 14:30, Jeff Hill wrote:
There isnt anything fundamentaly wrong with the streambuf
interface other than its complexity.
Hi:
My gut feeling is that it's so complicated
that it _must_ be fundamentally wrong.
Besides, even if I could understand it:
Can I actually use my own allocator & "char_traits"
on more than one compiler for more than one year?
Back to strings, memory in fixed chunks, and CA:
In order to have a client and server exchange
huge strings or custom data types, is it acceptable
to require a compatible configuration of memory chunk
sizes?
So is it unthinkable to restrict yourself to a
memory chunk size that - on vxWorks or RTEMS - will be configured
on startup and your strings have to fit in there?
So EPICS strings won't be limited to e.g. 40 chars.
On swapping operating systems they are even 'virtually unlimited',
and on e.g. vxWorks you can only serve strings that fit within
one memory chunk?
That way they don't need to be split across memory blocks,
and their interface can be C-style to which
every C++ class library (which of course comes with its custom
string class) can interface.
-Kay
RE: memory management Jeff Hill
Prev: RE: memory management Jeff Hill
Next: RE: memory management Jeff Hill
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
