2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: memory management
To: 'Kay-Uwe Kasemir' <[email protected]>
Cc: 'Bob Dalesio' <[email protected]>, 'Ralph Lange' <[email protected]>, 'Andrew Johnson' <[email protected]>, 'Matej Sekoranja' <[email protected]>, 'Ken Evans' <[email protected]>, 'Benjamin Franksen' <[email protected]>, 'Eric Norum' <[email protected]>, 'Marty Kraimer' <[email protected]>
Date: Wed, 02 Mar 2005 14:55:42 -0700
Hi Kay,
Its worth noting another fundamental difference between the
stringSegment and stream interfaces. A stream is templated
by the token type. The stringSegment assumes that
all tokens are convertable to type int, but stored in
implementation defined way. When copying between two
stringSegment of the same type no conversion occurs
and copies are very efficent. When copying between
different implemenations each element is converted to
and from type int. Therefore, stringSegment provides a
universal interface to different string implemenations
assuming that there is a universal integer wide code.
With standard streams there would need to be a different
overloaded function in dataAccess for each stream
template instantiation (character width).
We need to consider that there are many local
variations in how time and dates are converted to
strings. I suppose that different countries are also
using different decimal point characters and or
exponential notation letters? Berhaps thats less
of an issue.
So there is also the issue of the C++
locale facility. Its quite flexible, seems to provide
many important benefits, but also complex.
Since there are conversion functions in the stringSegment
interface we do not preclude use of the C++ locale facility
in the implementation. Nevertheless, when becoming dependent
on an implemenation we will need to carefully consider
this matter. Perhaps, our goal should be that the
string implemenation - especially the string to numeric
conversions - can be a site replaceable component.
> Back to strings, memory in fixed chunks, and CA:
> In order to have a client and server exchange
> huge strings or custom data types, is it acceptable
> to require a compatible configuration of memory chunk
> sizes?
Its probably a bad idea to require that the client
and server need to have compatible chunk sizes.
> So is it unthinkable to restrict yourself to a
> memory chunk size that - on vxWorks or RTEMS - will be
configured
> on startup and your strings have to fit in there?
> So EPICS strings won't be limited to e.g. 40 chars.
> On swapping operating systems they are even 'virtually
unlimited',
> and on e.g. vxWorks you can only serve strings that fit within
> one memory chunk?
> That way they don't need to be split across memory blocks,
> and their interface can be C-style to which
> every C++ class library (which of course comes with its custom
> string class) can interface.
The problem here will be storage inefficiency. The protocol
buffers will tend to use chunk sizes closer to the size of
Ethernet packets. Most strings will be very small. The
largest string might be gargantuan (but not for SNS PV names of
course).
Trying not to repeat mistakes I have made in the past, my
inclination is to design the stringSegment interface
to not preclude high performance implemenations based on
non-contiguous fixed sized blocks.
Jeff
Re: memory management Kay-Uwe Kasemir
Prev: Re: memory management Benjamin Franksen
Next: Re: memory management Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: memory management Kay-Uwe Kasemir
