2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: V4 design issue: Should primitive data types have well defined precisions?
To: EPICS Core Talk <[email protected]>
Date: Wed, 22 Jun 2005 06:38:26 -0500
I will argue that the answer should be yes.
epicsTypes is the proposed set of primitive types are well as proposed definition for string, array, and enum.
Without agreeing on a set of primitive data types, including the precision of each type, mismatches between data sources and consumers can easily occur.
Corba IDL, Java, and C# all use types short, int, long, float, and double but ALL define the exact precision for each. In fact they all use the sdame precision, i.e.
short 16 bits
int     32 bits
long  64 bits
float  32 bit IEEE float
double 64 bit IEEE float.
Marty
Re: V4 design issue: Should primitive data types have well defined precisions? Benjamin Franksen
RE: Puts Dalesio, Leo `Bob`
hello world examples Marty Kraimer
Re: hello world examples Ralph Lange
Re: hello world examples Marty Kraimer
V4 design issue: Should primitive data types have well defined precisions? Marty Kraimer
Prev: V4 design issue: Should primitive data types have well defined precisions? Marty Kraimer
Next: Re: V4 design issue: Should primitive data types have well defined precisions? Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
