Subject: |
Re: V4 design issue: Should primitive data types have well defined precisions? |
Benjamin Franksen <[email protected]> |
To: |
[email protected] |
Date: |
Wed, 22 Jun 2005 14:38:07 +0200 |
On Wednesday 22 June 2005 13:38, Marty Kraimer wrote:
> I will argue that the answer should be yes.
> epicsTypes is the proposed set of primitive types are well as
> proposed definition for string, array, and enum.
> Without agreeing on a set of primitive data types, including the
> precision of each type, mismatches between data sources and consumers
> can easily occur.
> Corba IDL, Java, and C# all use types short, int, long, float, and
> double but ALL define the exact precision for each. In fact they all
> use the sdame precision, i.e.
> short 16 bits
> int 32 bits
> long 64 bits
> float 32 bit IEEE float
> double 64 bit IEEE float.
According to DA philosophy the interface should /not/ enforce how
clients or servers store /their/ data.
I find this quite convincing: You cannot use a programming language
productively if you are forced to store the programs data in some
foreign format.
Jeff wrote some interesting things on IDL based approaches in the DA
tutorial. Notably, IDL based approaches /have/ to nail down all data
types, primitive as well as complex ones. DA was designed expressly to
avoid having to do this.
About mismatches: The current dbAccess interface where conversion is
automatic already risks mismatches all the time. You request a SHORT
from a LONG field, well that's your fault. So far nobody seriously
complained.
I assume that there /will/ be a way for the client code to find out
native (server or network side) precision and select its storage type
accordingly if necessary.
I suggest -- /especially/ in view of implementations in languages other
than C/C++ -- that we will have a /different/ DA for each language,
plus a DA-CA bridge to convert native to network types and vice versa.
DA itself should support whatever the language provides as primitive
data types. That is, if language X has a native String type, then X-DA
should support X-String; if X has native unsigned integers, X-DA should
support them; if X has bignums, so should X-DA have.
Yes, strings may be a primitive type in language X. So we don't even
have a clear distinction between primitive and complex data types. So
what?
Let me give one instructive example:
The Perl-DA would have /no/ distinction between primitive
types, /including/ strings, everything being a Scalar, period. Thus,
any sane implementation of a Perl CA Client Library would have to
auto-convert primitive types (including strings).
Yes, we probably don't want a native Perl CA Client Library. So this one
will build upon the C++ version. However, it is by no means necessary,
that a X-DA-CA bridge has to use all the available 'primitive' types.
Yes, at some point we will have to nail down CA network format. I
suggest that primitive types for the network layer should be as rich as
possible, /including/ unsigned types. Since each data transfer is
initiated (originally) by the client, communication with a native Java
client will simply never use those unsigned types, thus creating no
problem for the native client. A native Java server, OTOH, will never
expose unsigned data, so a client cannot request it, thus still no
problem.
Cheers,
Ben
- Re: V4 design issue: Should primitive data types have well defined precisions? Ralph Lange
- RE: Puts Dalesio, Leo `Bob`
- V4 design issue: Should primitive data types have well defined precisions? Marty Kraimer
- Re: V4 design issue: Should primitive data types have well defined precisions? Marty Kraimer
RE: hello world examples Dalesio, Leo `Bob`
<2005>
2025
2026
<2005>
2025
2026
