2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dataAccess V4 Ca client propertyId questions
To: EPICS Core Talk <[email protected]>
Date: Mon, 27 Jun 2005 16:23:15 -0500
Kay-Uwe Kasemir wrote:
I forgot the circumstances, but one point at the SLAC meeting
was that we might have to abandon the idea of "fred" == "fred.VAL".
True, and from that I developed the idea of supporting named views of the record. The dot now separates the record name from the view name, and some views will take simple parameters in parentheses.
If you want the default value, you'll have to use "fred.value"
in the new command-line 'caget' or the 'probe' GUI.
If you use "fred", you will get _all_ properties of fred.
Not quite. There should still be a default view for each record type, so you can still say "fred" and you'll get something analogous to the V3 "fred.VAL" default, but in V4 the record type has more control over what you will actually get back, and you will probably *not* get _all_ the properties, just the ones appropriate to the record's main value.
It'll be consistent for the whole hierarchy:
In case "fred.limits" is a structure, "fred.limits" will get
all structure elements. "fred.limits.display.high" might drill
down to a structure element.
Ammend that slightly: your "fred.limits" becomes "fred.field(limits)" to view the complete "limits" field structure, although if the record type defines a "limits" view then "fred.limits" would be correct. To drill down though you would have to use something like "fred.field(limits.display.high)"
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
views Kay-Uwe Kasemir
dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Prev: Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
Next: Re: More flexible record scanning Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Next: views Kay-Uwe Kasemir
