2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dataAccess V4 Ca client propertyId questions
To: EPICS Core Talk <[email protected]>
Date: Mon, 27 Jun 2005 15:35:12 -0500
On Jun 27, 2005, at 2:03 PM, Kay-Uwe Kasemir wrote:
On Jun 27, 2005, at 12:02, Marty Kraimer wrote:
Can it ask for a list of properrtyIds?
Given a list of propertyIds how does it obtain the information associated with each id?
The V4 "client user interface" suggests these in the "DataAccess" interface:
 	 list<string> getProperties()       Get a list of all the properties
 	 type_info getType(string property)
 	 string getAsString(string property)
I have been looking mostly at the dataAccess tutorial. I should have looked harder at eh dataAccess header files.
Sorry
Ca accepts a request to get data associated with a propertyId. Instead of putting it into a caller provided container via the caller supplied propertyCatalog, CA would make the data available via the caller supplied dataViewer.
We pretend that the CA client library & data access doesn't hold the data,
but only presents an interface for the user to copy the data into a
user-provided container.
I am looking at the V4 CA Interfaces document I printed from the wiki on 6/23. I may be out of date but I dont think so.
It is not clear how a read is performed.
channel.createReadRequest has a propertyCatalogRegistration argument.
What does this describe?
I assumed that it provides a propertyCatalg provided by the caller so that the CA client libary can use it to put data into a container provided by the caller.
But I see what you are saying. The read request provides a readCompletionNotify which has a method
  void success(... , const propertyCatalog &catalog);
This seems to mean that the requester must implement dataViewer so that it can call catalog.traverse to get the data it wants. Does this means that the caller must implement all the overloaded reveal methods? That is all the primitive types, the string segment method, etc. It would seem that at least the primitive types must be implemented.
If I understand dataAccess, implementing a robust propertyCatalog is a lot easier than implementing a dataViewer or dataManipulator because of all the overloaded reveal methods.
Thus I do not understand hoe a read is done.
Well, while you use dataAccess, the CA client library actually holds
the data in some temporary network buffer.
So you don't need a container at all if you only want to get a list
of all the properties & types.
 Does the proposed CA V4 interface allow this?
Yes, Jeff proposes a channel::createAllPropertiesReadRequest.
Does that cover your idea for a simply 'probe'- type application?
     foreach p ( da->getProperties() )
         display da->getType(p), da->getAsString(p)
... or would you also like to see a request that only
gets the properties and types, without fetching any actual values?
The latter. I think Jeff alluded to this but do not know when.
A primary reason is arrays. If the array is huge, e.g. a many megabyte image, then it should not be necessary to retrieve the image just to find out it's properties.
Marty
-Kay
dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Prev: Re: connections, beacons, ...: Only directory and TCP? Matthias Clausen
Next: Re: dataAccess V4 Ca client propertyId questions Andrew Johnson
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Next: Re: dataAccess V4 Ca client propertyId questions Ralph Lange
