2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dataAccess V4 primitive types
To: EPICS Core Talk <[email protected]>
Date: Thu, 30 Jun 2005 14:00:49 +0200
Marty Kraimer wrote:
I suspect, however, that specifying how type_info is defined will lead to lots of debate starting with the definition of primitive types and then strings and arrays and then structured data.
Benjamin and I didn't want to lose discussion time and decided to go ahead starting that debate ....
Our idea is to /not/ make that type info a simple fixed enumeration of fixed types, but use a dynamic structure to describe a type. We came up with the following:
type         =   string                      1)
              | timestamp                   2)
              | signed (bitwidth)           3)
              | unsigned (bitwidth)         3)
              | float (float_format)
              | struct                      4)
              | array (base_type, size)     5)
float_format = ieee32 | ieee64 | ieee80
Annotations:
1) String should be a basic atomic type - regardless of its implementation.
2) For efficiency reasons (as timestamps are shipped around and handled all the time) the timestamp should be an atomic type that can easily be mapped and assigned to the EPICS supported C/C++ types.
3) A server or client app can choose any locally available data type that is appropriate and wide enough to store the data. Future wider integers are supported. As for signedness, alternatively there could be one integer type with another parameter giving the integer format:
              | integer (int_format, bitwidth)
with
int_format   =   unsigned |signed
4) This basic type is needed for properties that actually are a contained list of other properties.
5) base_type is another type_info. If we need a type where arrays do not start with element zero, size might be replaced by a (min, max) pair. Multi-dimensional arrays are represented as arrays of arrays.
This type_info has a dynamic size (it's a union - which really seems to be a natural way to describe lots of things...). Making itself a property catalog seems a slim and convenient way to interface it.
IOC side ideas:
It is perfectly allright for the IOC Database implementation to use a fixed enumerated number of fixed types. This may be the most efficient implementation. When the CA connection is made, the CA server will have to find out about the types of a property catalog owned by a record using the type_info to decide which network representation it uses for the data. In case of a fixed list of enumerated fixed types, a bunch of static property catalogs will be enough to fulfill most of these type_info requests. A plain table can hold the connections between fixed types and their type_infos. (There's no need to generate a type_info property catalog for each record instance nor for each record type.) For menus, the needed bitwidth could be reported correctly to the CA server, as the number of choices is fixed at compile time. This would allow CA and the client side to optimize storage - independent from the implementation in the IOC Database.
Possible DBD look-and-feel:
Wouldn't have to change. If the Database is implemented using predefined fixed types, everything stays the same. Otherwise, the parametrized types would be used instead of the fixed ones, i.e.
int32    would become  signed(32)
float64  would become  float(ieee64)
and so on.
So much for the first iteration....
Benjamin and Ralph
Re: dataAccess V4 primitive types Marty Kraimer
Re: dataAccess V4 primitive types Andrew Johnson
dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Ralph Lange
Prev: Record support and user-defined fields Benjamin Franksen
Next: Re: dataAccess V4 primitive types Marty Kraimer
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
