2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: dataAccess V4 primitive types
To: Ralph Lange <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Thu, 30 Jun 2005 16:05:54 -0500
Ralph Lange wrote:
Our idea is to /not/ make that type info a simple fixed enumeration of fixed types, but use a dynamic structure to describe a type.
Interesting idea, although I worry slightly about what it will do to performance. See below though...
We came up with the following:
type         =   string                      1)
              | timestamp                   2)
              | signed (bitwidth)           3)
              | unsigned (bitwidth)         3)
              | float (float_format)
              | struct                      4)
              | array (base_type, size)     5)
Can we add a generic 8-bit byte type, which allows specialized data types to be stored in an array of bytes. In RDB terms this gives us BLOBs.
float_format = ieee32 | ieee64 | ieee80
I don't particularly like the "ieee32" and "ieee64" encoding, why not just use a bitwidth?
IEEE 754 defines single precision (32-bit) and double precision (64-bit) formats explicitly, but beyond that it defines a *class* of double extended precision formats which are not portable between CPU families. SPARC uses a quadruple precision format which is 128 bits wide, while 68k and x86 have 80-bit formats which actually take 96 bits to store (16 of these are unused, and there are also endian differences which affect the layout). I don't think we should be adding long double (ieee80) because of this portability issue, and also because I've not heard anyone suggesting they might need more precision.
Annotations:
1) String should be a basic atomic type - regardless of its implementation.
<pedantic>
I think you mean "fundamental" rather than "atomic", to which I agree. To me the term "atomic type" means one which can be read/written in a single CPU read/write cycle so that it will always self-consistent even in the presence of interrupts, DMA or multiple threads or processors that could cause the value to be changed while you're accessing it.
</pedantic>
2) For efficiency reasons (as timestamps are shipped around and handled all the time) the timestamp should be an atomic type that can easily be mapped and assigned to the EPICS supported C/C++ types.
3) A server or client app can choose any locally available data type that is appropriate and wide enough to store the data. Future wider integers are supported. As for signedness, alternatively there could be one integer type with another parameter giving the integer format:
              | integer (int_format, bitwidth)
with
int_format   =   unsigned |signed
I still question the need to support unsigned integer types at all. If we want to transfer bit-array data (the most common use for unsigned types if you exclude Jeff's code), they should be sent as an array of bytes.
4) This basic type is needed for properties that actually are a contained list of other properties.
5) base_type is another type_info. If we need a type where arrays do not start with element zero, size might be replaced by a (min, max) pair. Multi-dimensional arrays are represented as arrays of arrays.
Our basic array types should only support a zero-based index; anything else can easily be derived.
This type_info has a dynamic size (it's a union - which really seems to be a natural way to describe lots of things...). Making itself a property catalog seems a slim and convenient way to interface it.
It's not a union (which is not type-safe); it's a pointer to an abstract base class, and a set of derived classes with a single instance of each type.
Inside the IOC we'd be passing around and comparing these pointers. Hmm, those object could provide methods to allow you to manipulate and string-convert values. We could even make use of the C++ std::type_info class and the std::typeid() routine somehow...
Am I heading off in completely the wrong direction here?
Possible DBD look-and-feel:
Wouldn't have to change.
Agreed. In the IOC code we'll use concrete types like epicsInt32, and the DBD file will define fields of that type using "int32".
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Re: dataAccess V4 primitive types Benjamin Franksen
dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Kay-Uwe Kasemir
Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
Re: dataAccess V4 Ca client propertyId questions Ralph Lange
Re: dataAccess V4 primitive types Ralph Lange
Prev: Re: dataAccess V4 primitive types Marty Kraimer
Next: Re: dataAccess V4 primitive types Benjamin Franksen
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
