2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record support and user-defined fields
To: EPICS Core Talk <[email protected]>
Date: Thu, 07 Jul 2005 14:51:32 -0400
On Jul 7, 2005, at 14:26, Andrew Johnson wrote:
Can I get you two to think about these requirements at a slightly higher level and describe what it is you're trying to achieve, rather than how we should actually implement it.
Things I had in mind:
- Add a 'maximum' or 'average' to some ai, ao, calc, subroutine, ...
  record instances
- Add a(n additional) forward link to a record
- Make a record post all/some values to a logging facility
  or circular buffer
In case of the max., average, ..., I think it would be really nice
to have this as a field of the record. How else would I access
the current maximum? I'd like to access it via CA, see it in dbpr, ...
I'm all for easing the creation of new record types, so one could create
a new record type that includes this new 'MAX' field.
But I don't want it in every ai, ao, ....,
neither do I like creating an ai, ai_max, ai_avg, ai_max_and_avg, ao, ao_max, ....
just to cover all permutations, I simply want to add the MAX and/or AGV
field to selected records.
Actually, I don't use the FLNK, HIGH, SIML, ... fields in most records,
so could they all go and only be added as required?
For put logging etc., having a new string field that accepts
some configuration parameter also sounds useful, although not essential.
So I see no basic problem with adding a field at runtime,
only benefits.
We can discuss the details of my proposal:
Only 2 hooks into the process() routine, ... see pro/cons on the wiki.
But then you just suggested _not_ to look at implementation details, yet ;-)
If I can suggest an alternate approach that could provide this functionality but doesn't involve "adding a field at runtime", would you accept this instead?
Absopositively. What do you suggest?
-Kay
Re: Record support and user-defined fields Andrew Johnson
V4 iocRecord: forward linking Ralph Lange
Re: Record support and user-defined fields Benjamin Franksen
Re: Record support and user-defined fields Kay-Uwe Kasemir
Prev: RE: name resolution performance Jeff Hill
Next: Re: Record support and user-defined fields Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Record support and user-defined fields Andrew Johnson
