2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: V4 iocRecord: forward linking
To: EPICS Core Talk <[email protected]>
Date: Wed, 29 Jun 2005 13:34:59 +0200
The current FLNK implementation in V3 (and also what's on the wiki for V4) is a single link field.
My experience is that in most cases you either don't need an FLNK or you actually need multiple FLNKs (usual workaround is linking the targets in a chain through their respective FLNKs or using a fanoutRecord). In other words: the implementation matches exactly the least common situation. Not good.
Suggestion:
For V4, make FLNK an array of links with a default size of zero.
This uses less space in the most common case, allows for very flexible FLNKing, and it eliminates the need for a fanoutRecord.
Ralph
Re: V4 iocRecord: forward linking Kay-Uwe Kasemir
Prev: Re: More flexible record scanning Benjamin Franksen
Next: Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: ANL Gate Passes Andrew Johnson
Next: Re: V4 iocRecord: forward linking Kay-Uwe Kasemir
