2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: More flexible record scanning
To: [email protected]
Date: Wed, 29 Jun 2005 11:20:39 +0200
On Tuesday 28 June 2005 16:42, Andrew Johnson wrote:
> Benjamin Franksen wrote:
> > Event scanning using raw numbers is much too fragile.
> That I accept; in V4 we should consider changing the EVNT field to
> become something like a string or better yet, an extensible menu
> (I've just added a note about such a requirement to the DBD Statement
> Syntax wiki page on menu definitions).
> > In contrast, an input link for the PROC field never accidentally
> > 'leaks' to the outside, at least if the 'scanning' record instance
> > is part of the same database file.
> What does a "Backward" link really mean, how do you implement it,
No, I meant a normal input link! You can make it CPP or CP, of course,
like any input link. Very simple.
> and
> is it really worth the overhead (which would be more than just one
> additional link in every record)?
Yes, having it in dbCommon would cause some overhead. I remember that
there was a proposal to add ad-hoc fields to record instances in V4. If
we have this, it would be easy to add such a link field only to those
records that need them.
> For CA links the meaning is
> probably relatively clear: "process me whenever you get an event from
> that channel", and the CA client library already provides the
> necessary infrastructure.  However to implement it for a DB link we
> would have to:
> * Add the "Backward" link to dbCommon
> * Add a linked list to dbCommon, containing pointers to all the other
> records that have a "Backward" link to this record
> * When initializing the database, construct the linked lists for all
> records * After (or before?) processing the FLNK of a record, also
> scan that linked list and process all the records on it
> * Perform special handling for "Backward" links whenever they get
> changed, deleting the link owner from its target's old list and
> adding it to the new target's list (this processins requirement is
> unique, we never have to do anything like it for any other link
> fields)
> IMHO this is unnecessary, and adding it would be using a sledgehammer
> to crack a nut (as would using an empty tagged union to implement
> enum/menu).
Yes, of course & completely agreed. I never proposed an additional input
link /type/, just an additional (ordinary) link /field/.
Ben
Re: More flexible record scanning Andrew Johnson
More flexible record scanning Benjamin Franksen
Re: More flexible record scanning Benjamin Franksen
Prev: ANL Gate Passes Andrew Johnson
Next: V4 iocRecord: forward linking Ralph Lange
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: More flexible record scanning Andrew Johnson
Next: Re: More flexible record scanning Andrew Johnson
