2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: More flexible record scanning
To: [email protected]
Cc: [email protected]
Date: Tue, 28 Jun 2005 09:42:33 -0500
Benjamin Franksen wrote:
Event scanning using raw numbers is much too fragile.
That I accept; in V4 we should consider changing the EVNT field to become something like a string or better yet, an extensible menu (I've just added a note about such a requirement to the DBD Statement Syntax wiki page on menu definitions).
In contrast, an input link for the PROC field never accidentally 'leaks' to the outside, at least if the 'scanning' record instance is part of the same database file.
What does a "Backward" link really mean, how do you implement it, and is it really worth the overhead (which would be more than just one additional link in every record)? For CA links the meaning is probably relatively clear: "process me whenever you get an event from that channel", and the CA client library already provides the necessary infrastructure. However to implement it for a DB link we would have to:
* Add the "Backward" link to dbCommon
* Add a linked list to dbCommon, containing pointers to all the other records that have a "Backward" link to this record
* When initializing the database, construct the linked lists for all records
* After (or before?) processing the FLNK of a record, also scan that linked list and process all the records on it * Perform special handling for "Backward" links whenever they get changed, deleting the link owner from its target's old list and adding it to the new target's list (this processins requirement is unique, we never have to do anything like it for any other link fields)
IMHO this is unnecessary, and adding it would be using a sledgehammer to crack a nut (as would using an empty tagged union to implement enum/menu).
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Re: More flexible record scanning Benjamin Franksen
Re: More flexible record scanning Andrew Johnson
Prev: Re: dataAccess V4 Ca client propertyId questions Ralph Lange
Next: ANL Gate Passes Andrew Johnson
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: More flexible record scanning Benjamin Franksen
Next: Re: More flexible record scanning Benjamin Franksen
