2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: More flexible record scanning
To: [email protected]
Cc: [email protected]
Date: Wed, 29 Jun 2005 11:30:07 -0500
Benjamin Franksen wrote:
On Tuesday 28 June 2005 16:42, Andrew Johnson wrote:
What does a "Backward" link really mean, how do you implement it,
No, I meant a normal input link! You can make it CPP or CP, of course, like any input link. Very simple.
"Backward link" is just my name for your input link; I don't want any common feature like this to only work with CA links (there should be nothing special about CA links in V4, they'll be just another kind of link support). Your "very simple" implementation idea is guaranteed to only work with CA links that are CP/CPP, and I don't like that at all. To support it for DB links, we'd have to add all the stuff I talked about since we don't yet have change event notification on input DB links.
I really don't want us to add "Backward links" to EPICS; we should fix the event scan as the solution to your original issue.
That does bring up the point that there is a significant difference in a CA link that is CP/CPP than most other kinds of link: the "process me on change event" behaviour is unique for an input link, and we should think about whether we could have a standard way to support that for other link types. There is something conceptually very similar about it to I/O interrupt scanning from an input device support -- could we create a single mechanism that implements both? Maybe remove I/O Interrupt from the list of scan types even...
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
More flexible record scanning Benjamin Franksen
Re: More flexible record scanning Benjamin Franksen
Re: More flexible record scanning Andrew Johnson
Prev: Re: V4 iocRecord: forward linking Kay-Uwe Kasemir
Next: Re: dataAccess V4 Ca client propertyId questions Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: More flexible record scanning Benjamin Franksen
Next: Re: Version 4 EPICS Ralph Lange
