2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: V4 iocRecord: forward linking
To: EPICS Core Talk <[email protected]>
Date: Wed, 29 Jun 2005 12:13:55 -0400
On Jun 29, 2005, at 07:34, Ralph Lange wrote:
Suggestion:
For V4, make FLNK an array of links with a default size of zero.
The user-defined field would also allow for no default FLNKs at all,
then the user adds as many as needed.
That way you could have nice looking field names:
user_field(convert_units, "MyConversionCalcRecord", fwd_link_handler); user_field(determine_output, "MyOutputCalcRecord", fwd_link_handler); user_field(write_output, "MyOutputRecord", fwd_link_handler);
instead of FLNK[0..2].
FLNKs do seem fundamental enough, though,
that I agree with putting them into the base record,
where they might process faster.
One question about processing:
In the current a.FLNK -> b.FLNK -> ... chain,
each individual record's process() routine could decide on its own
as to how it handles the process links.
If b is async, we're waiting until it ends processing
because b decides when to invoke the FLNK.
Will FLNKs[0...N] simply get processed and the originating record
is done, or will it process & wait for completion of FLNK[0],
then proc & wait for FLNK[1], ... ?
-Kay
Record support and user-defined fields Benjamin Franksen
V4 iocRecord: forward linking Ralph Lange
Prev: views Kay-Uwe Kasemir
Next: Re: More flexible record scanning Andrew Johnson
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: V4 iocRecord: forward linking Ralph Lange
Next: Record support and user-defined fields Benjamin Franksen
