Benjamin Franksen wrote:
Another point: What is the use of the method definition, apart from
generating a C++ member declaration? If there is no other use, we can
avoid it by using a regular top-level procedure, as shown in my
proposal on the wiki. I ask because I find it somewhat ugly to cite a
foreign language (C++) term inside the dbd file. I know, we already do
this for DBF_NO_ACCESS fields, but I never liked that one either (and I
believe it can be avoided, too).
It also documents the methods available for the record support user, and
means we don't have to have your parallel xxxStructSupport.h file which
contains just those declarations. The DBD file contains the *complete*
interface to the structure and its methods, and the record support code
that calls it is easier to understand. If the method is short enough it
could even be defined inline inside the string itself..
It would be possible to replace the line
method("STATUS constrain(ValType &value)")
with something like
method(constrain) {
returns(STATUS)
argument(value, reference(ValType))
but IMHO that would be pointless - it's less flexible, a lot more effort
to parse and convert, and totally unnecessary since the only direct
interface we're providing to the structure is through C++ code anyway.
One minor detail: We should have a consistent scheme for C/C++ entities
generated from dbd definitions.
Agreed, although we might need reminding about that later once we get to
that level of detail.
Wow. A dedicated DBD/DB extension language. Let me think a while
about /that/ one, before I comment...
Please don't spend time on that, IMHO it's way too ambitious to ever
happen (unless you're also offering to do all the work implementing it
as well...).
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
- Re: Record support and user-defined fields Benjamin Franksen
- V4 iocRecord: forward linking Ralph Lange
- Re: Record support and user-defined fields Andrew Johnson
Re: V4 EpicsString Andrew Johnson
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
