On Tuesday 12 July 2005 15:43, Marty Kraimer wrote:
> The following can be defined:
> menu(invalidAction) {
> choice(invalidActionContinue_normally,"Continue normally")
> choice(invalidActionDon_t_drive_outputs,"Don't drive outputs")
> choice(invalidActionSet_output_to_IVOV,"Set output to IVOV")
> struct(invalidOutput, type {
> field(invalidAction,menu(menuIvoa))
> field(invalidValue,Value)
> And then the record.dbd would be
> field(invalidOutput,struct(invalidOutput,float64))
> field(output,device(none,processInvalidOutput))
Fine. Do we agree that we may need more than one type parameter in
struct definitions? (Although it will probably not be very common). The
following should be allowed (for n >= 0):
struct(structName, type_var_1, type_var_2, ..., type_var_n) {
and then in a record type definition
field(fieldName,struct(structName, type_1, ..., type_n))
> And the interface definittion becomes
> Some .h file contains:
> class processInvalidOutput {
> virtual void compute(invalidOutput<epicsInt32>
> &output,,epicsString &status, epicsInt16 &severity);
> ... // perhaps other types for value
Assuming you meant to write 'invalidOutput<epicsFloat64>' in one of the
two methods above, this still falls short of a real templatized
version:
template <typename ValueType>
void compute(invalidOutput<ValueType>&output, epicsString &status,
One must be very careful in C++ with overloading. If in the above
example you forget to declare a method for invalidOutput<epicsInt16>,
the argument will silently be converted/promoted to the next larger
numeric type, like in C. This might be compiler dependent. I have no
idea what happens if the reference is used to overwrite the value
field; maybe the compiler disallows it but then generality suffers,
i.e. you cannot use the struct/template/device-whatever for numeric
types other than the ones you provide definitions for.
Templatizing the method leads to more predictable behavior (no
conversions). However, it also has some disadvantages:
o Compiler error messages can become somewhat lengthy and obscure.
OTOH, I rather get a confusing and hard to decipher error message
from the compiler than strange behavior at run-time.
o More serious: it depends on the implementation of the (templatized)
method, which types are actually allowed in instances. For instance,
if a '<' operator is used on the value, compilation will fail if
instantiated with a type that has no operator '<' defined.
I am uncertain how much of a problem the latter problem is going to be
in practice. If someone wants to instantiate such a template for an
unexpected type and the compiler complains, the record type designer is
free to provide the expected operations (for instance, an operator
'<'). If that is impossible or just impractical, the instantiation
probably doesn't make sense anyway. I still don't like it, because it
means I must take back my claim that I can give a C==-independent
self-contained definition of what type parameters in the DBD file mean.
Hmmm.
> and the process method calls
> pprocessInvalidOutput->compute(invalidOutput,status,severity);
Ben
- Re: Record support and user-defined fields Benjamin Franksen
- Re: Record support and user-defined fields Marty Kraimer
- V4 iocRecord: forward linking Ralph Lange
Re: V4 Design: Record Processing Benjamin Franksen
<2005>
2025
2026
<2005>
2025
2026
