2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Fwd: RE: Standard String]
To: Kay-Uwe Kasemir <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 18 Jul 2005 12:55:29 -0500
Kay-Uwe Kasemir wrote:
but I still don't see a way around contiguous char * strings,
because that's what most 'legacy' libraries want.
You can add that as a layer around the next EPICS String class
and copy char by char from the non-contig. String into a char *,
but std::string and MFC::CString instead bite the bullet
and provide a c_str() type of method.
In our EpicsString design, we solved this requirement by including a buffer type that stores contiguous zero-terminated data (the other buffer types don't have to guarantee a zero terminator). If you need to pass a string to an external library then you can create one of these and copy the string to it, or just use that buffer type in the first place if it's your string and you're not concerned about reallocating memory if it ever needs to be extended.
It is possible to design a full implementation of C++ std::string that uses segmented memory. The assumption is that c_str() would rarely be used, but when it is the implementation just allocates a contiguous buffer and copies the segmented string into it. The C++ standard states two requirements for c_str(): "The program shall not alter any of the values stored in the array. Nor shall the program treat the returned value as a valid pointer after any subsequent call to a non-const member function" Thus the implementation may release the contiguous buffer it allocated the next time the user attempts to alter the string.
I am not advocating that we use this approach in our string class, just illustrating that the C++ standards writers saw that they had to provide a char* accessor method for interfacing to legacy systems.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
RE: [Fwd: RE: Standard String] Jeff Hill
Re: [Fwd: RE: Standard String] Kay-Uwe Kasemir
Prev: RE: [Fwd: RE: Standard String] Jeff Hill
Next: RE: [Fwd: RE: Standard String] Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
