2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Standard String
To: [email protected]
Date: Wed, 20 Jul 2005 10:07:11 -0500
This is a response to the discussion of what a standard string should be and to Kay's message about "Type descriptor vs enum"
I want to go back to my message about Network Accessable Types. I proposed:
enum NadType {
  nadTypeUnknown,
  nadTypeBoolean,
  nadTypeOctet,
  nadTypeInt16,
  nadTypeUInt16,
  nadTypeInt32,
  nadTypeUInt32,
  nadTypeInt64,
  nadTypeUInt64,
  nadTypeFloat32,
  nadTypeFloat64,
  nadTypeString,
  nadTypeArray,
  nadTypeMDArray,
  nadTypePropertyCatalog,
  // Following are usefull common types
  nadTypeTimeStamp,
  nadTypeEnum,
  nadTypeMap
This leads to a discussion of what is the actual type associated with each NadType.
The types Boolean, ..., Float64 SHOULD be easy but I am no longer sure because each may cause a class war, i.e. "Your class hierarchy sucks. Mine came by devine revelation"
The other types are not at all obvious. I started the discussion of Standard String with nadTypeString in mind. I hoped that if we could agree on a standard way to handle strings then the type associated with nadString would be a by product. The discussion that resulted showed this to be a mistaken hope.
It soulds like we may never agree on an EpicsString so lets just discuss what if needed for NadString.
Lets step back and ask "What is needed for the types associated with each NadType?"
The type must be something that can make the associated data accessable without any knowledge about what holds the data. The communicating entities may be in different locations and may be using different languages. This implies that the actual types depend on the language. But we can decide what the semantics should be. Also we should be able to define something so that it can be implemented in both C++ and Java.
The rest of the message will only discuss how to create an interface for nadTypeString.
What are the requirements:
1) It only supports UTF-8 encoded strings.
2) It must be possible to both read and write UTF-8 encoded strings.
3) The container may only be able to handle the data in chunks.
How should it be implemented?
I will agree with Jeff that an interface (C++ pure virtual base class, Java Interface) should be defined. The code that holds the container can do whatever it wants but should make the interface available so that other code can read and write UTF-8 strings.
All talk about constructors should not be part of the discussion
So how do we define it? Perhaps somthing like (Java syntax) :
Note: I will assume that nadOctet is a type that is an 8 bit byte and nadInt32 is a 32 bit integer
interface NadString {
   nadInt32 get(nadInt32 offset, nadInt32 len, nadOctet *pto);
   nadInt32 put(nadInt32 offset, nadInt32 len, nadOctet *pfrom);
   void reserve(nadInt32 capacity);
   nadInt32 capacity();
   bool mutable();
Some rules:
1) All sizes are in units of octets, NOT UTF_8 characters.
2) get and put return actual number of octets transfered. The caller must be prepared to make multiple calls.
3) reserve tells the container that this many octets will be put.
4) capacity() can be called to find out how many bytes may be obtained via gets.
5) mutable() false means that put and reserve will cause an exception.
Marty
Network Accessable Data Marty Kraimer
FW: Standard String Jeff Hill
Re: FW: Standard String Benjamin Franksen
Re: Standard String Kay-Uwe Kasemir
Prev: RE: Type descriptor vs. enum Dalesio, Leo `Bob`
Next: Re: Standard String Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Standard String Kay-Uwe Kasemir
Next: Network Accessable Data Marty Kraimer
