2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Standard String
To: [email protected]
Date: Wed, 20 Jul 2005 10:12:39 -0500
Kay-Uwe Kasemir wrote:
do you know any example where you actually need to destructively update a string,
once you have it constructed?
I think Ben is right here.
I disagree, or maybe I don't fully understand the suggestion.
There is a record type called the stringCalc record, which is used extensively by the BCDA group's synApps software (among other things, it permits you to interface to new ASCII devices without having to write device support). The VAL field of a stringCalc is string, which is regenerated every time the record processes. I don't know how you would implement this record type if all strings become read-only once created.
Similarly any device support that is driving a message-based device has to be able to create a new message every time it processes; if we don't support mutable strings, these device supports would have to use char* buffers for generating their messages in.
I think we need to concentrate on the 99% where the string
is a short, contiguous (char *),
instead of the 1% where the string
is 1MB long, stored as non-contiguous 10 byte segments.
As I understand it, one of the main purposes of the segmented string requirement is to permit Jeff to create a complete string out of the characters that appear in the CA network input buffer, without having to copy the character data at all. The chances that even a short string would span two (or more) buffers are not that small, and the implications of his having to copy the data are not just the time taken to do the copy - if we force him to copy it out of the buffer before presenting the string to the application, he has to temporarily allocate memory for the destination string, and then manage the lifetime of that memory allocation.
Sorry guys, I really can't support the development of an API that only supports non-modifyable strings.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Re: Standard String Kay-Uwe Kasemir
FW: Standard String Jeff Hill
Re: FW: Standard String Benjamin Franksen
Prev: Re: Standard String Marty Kraimer
Next: Re: Type descriptor vs. enum Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: String Interfaces Jeff Hill
Next: Re: Standard String Kay-Uwe Kasemir
