On Wednesday 20 July 2005 18:11, Andrew Johnson wrote:
> Kay-Uwe Kasemir wrote:
> > How would you prefer to handle these?
> > a) equip the EpicsString class with all the methods
> > to change/insert/delete character sequences at any
> > position in the string
> > b) have a
> > char buf[...]
> > where you can to all the character fiddling,
> > then attach a string interface to that in order
> > to hand it to the CA Server or other EPICS entity?
> > So this String class would actually be non-mutable,
> > it only provides read-access to the user-owned buf.
> > I would prefer b, so we have another example for
> > my case that the most important task of the string class
> > it to interface with char *.
> c) Design the string class so that it has an internal API giving
> access to the raw data buffer. Provide a set of manipulator
> functions that use this API to perform the string operations that we
> need. Permit anyone else to write additional manipulators for
> operations they need which we haven't implemented.
d) Variant of b): Have a separate class for constructing a string. It
should maintain a current char[] buffer, so that characters can be
efficiently appended, but is extensible in size and supports operations
like DA's streamWrite (with write position at the end only).
On Wednesday 20 July 2005 17:12, Andrew Johnson wrote:
> There is a record type called the stringCalc record, which is used
> extensively by the BCDA group's synApps software (among other things,
> it permits you to interface to new ASCII devices without having to
> write device support). The VAL field of a stringCalc is string,
> which is regenerated every time the record processes. I don't know
> how you would implement this record type if all strings become
> read-only once created.
You already answered your question: The string gets regenerated every
time. It's a new string, different from the old one. No destructive
update of the string is necessary to achieve that.
Ben
- Re: Standard String Andrew Johnson
- FW: Standard String Jeff Hill
- Re: Standard String Kay-Uwe Kasemir
RE: Network Accessable Types Jeff Hill
Network Accessable Data Marty Kraimer
<2005>
2025
2026
<2005>
2025
2026
