2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Standard String
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Wed, 20 Jul 2005 15:02:01 -0500
Benjamin Franksen wrote:
how you would implement this record type if all strings become
read-only once created.
You already answered your question: The string gets regenerated every time. It's a new string, different from the old one. No destructive update of the string is necessary to achieve that.
So every time you process the record, you free() the old string buffer and malloc() at least one new one, if not several as we extend the string? I don't see how that helps us at all, so I'm probably not understanding what you meant.
You have a record (a struct) that contains a string field as a data member. If you say I can't modify the string, and I say I can't move the record in memory, how do I change the value of that string field?
The current EPICS code only allocates memory for database storage at dbLoadRecords() and iocInit() time, for a very good reason: continual allocation and freeing of memory *will* fragment the IOC memory pool into smaller and smaller chunks (we know that from experience, and take some special precautions inside iocCore which you may not be aware of). The vxWorks memory allocator is *particularly* bad when it comes to fragmentation, but even using a better allocator it's not going to be possible to run an IOC for months or even years without rebooting if it's continually churning its memory.
Please remember that we have to be able to run on small footprint systems with 8MB or maybe 16MB of RAM (I think we said 8 at the meeting last week), and there's no virtual memory so no swapping or paging possible on these small IOCs.
- Andrew
Podiabombastic: The tendency to shoot oneself in the foot.
Re: Standard String Benjamin Franksen
FW: Standard String Jeff Hill
Re: Standard String Kay-Uwe Kasemir
Re: Standard String Andrew Johnson
Prev: Re: Type descriptor vs. enum Benjamin Franksen
Next: Re: Standard String Benjamin Franksen
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Standard String Benjamin Franksen
