On Wednesday 20 July 2005 16:47, Dalesio, Leo `Bob` wrote:
> There are use cases on the wiki.
> There are two thoughts on this
> -- you are told the type
> -- you are not told the type
> Could we work out the use cases with either approach?
I have been thinking about this, too. I think that a better way to
describe the two cases is
- Client knows the type, or at least knows a suitable supertype large
enough to hold the data, eitehr by design or by user configuration.
Examples: Display managers, command line tools (common usage), all
applications written for a specific database.
- Client must exactly reflect the server type, but has no way of knowing
the type beforehand. Examples are: Gateway, Archiver. I tink that only
fully generic applications need this.
> Ben - you handle -- not told the type
This case is completely solved by Data Access. There are things in it
that could be improved (like making streamWite and streamRead objects
separate from string) but at least I think it contains the needed
functionality.
> Kay - you handle -- told the type
This would be solved as soon as Jeff and Ralph manage to publish the
PropertySurveyor interface.
Jeff: why don't you just put all the latest header files on the wiki? Or
at least give us a link where one can download them so that we can take
a look at the current state of affairs?
Ben
- RE: Type descriptor vs. enum Dalesio, Leo `Bob`
Network Accessable Data Marty Kraimer
Re: Standard String Andrew Johnson
<2005>
2025
2026
RE: Type descriptor vs. enum Liyu, Andrei
<2005>
2025
2026
