2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ICE and TIPC
To: [email protected]
Date: Thu, 28 Jul 2005 12:29:58 +0200
Andrew Johnson wrote:
Shouldn't a propertySurveyor also be given access rights information (i.e. whether a particular property is writable or not)? Do you intend to use a different mechanism to communicate that somehow? Unfortunately your very clever template mechanism only works with fully symmetrical property sets; in many cases I think we're going to have to write all three traverse() routines ourselves, to cope with read-only properties.
This is a really interesting issue - here's what I've been thinking:
To avoid loads of exception being thrown, the traverse methods should only reveal properties that are appropriate for the traverse's use. The viewer traverse should only reveal properties that are readable, the manipulator traverse should only reveal things that are writable, the surveyor traverse should reveal everything that's available including the information if something is writeable. This works so far, as DA only distinguishes between read-only and read-write properties.
So - what are we doing with access rights that are based on AccessSecurity?
For V3, AccessSecurity stuff is spread through different layers:
- For the client, AccessSecurity change callbacks and the related stuff are an integral part of ChannelAccess and its network protocol; access rights info is closely coupled to the data
- The CA server does the client authentification (checks user and host name)
- A separate module (i.e., library) holds the AccessSecurity configuration and does the on-line rule-based checks (including CALC based rules that have other CA client connections) - The database definition (dbd file) holds the AccessSecurity level info per field (as part of the record definition) - The database (db) holds the AccessSecurity group info per record instance (as ASG field of record instance)
If we try to copy the functionality to V4 with the least changes in structure and mechanisms, the service (EPICS database) will still have to hold and provide AS level and group info to the server(s). These would probably be implemented as properties in the record's views: Group info as a top level property (or somewhere on record level), AS level info as a subordinate property - for every property. (Is there a way to make this easier?)
The server (in this case CA) will have to use that information and will probably continue to use the checks of the AS library.
How will the AS info be connected to the property catalogs?
I see problems with Jeff's initial suggestion ("When implementing a property catalog for an EPICS PV there may also need to be subordinate properties for the access rights so that they might be dynamic."): A property without read-access will disappear from the viewer-traverse - and with it a subordinate property will simply go away. The client subscribing to this sub-property will probably get a connection loss exception thrown. My favourite solution at the moment: (btw. I have been mentioning this problem and my suggestion in several emails without reaction) The access rights property is completely taken out of the data and the CA server reveals it as part of the surveyor traverse. That way it is assured that it always exists (even if read-access to the data is taken away) and clients get updates for a subscription as they expect.
Ralph
Other question: Will we keep the same mechanisms for Access Security in V4? Are there other techniques that should be implemented or at least made feasible by defining appropriate AS plug-in APIs? What about the user/password credentials (probably checked against an auth server) that we saw at the ABB show? I liked that, admittedly. Is the AS group and level info in the EPICS database generic enough to support other security mechanisms?
RE: ICE and TIPC Jeff Hill
Re: ICE and TIPC Andrew Johnson
Prev: Re: next meeting before EPICS meeting at Archamps? Ralph Lange
Next: Re: DA / Generic Container Yard Ralph Lange
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ICE and TIPC Jeff Hill
Next: RE: ICE and TIPC Jeff Hill
