2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access Client Interface
To: EPICS Core Talk <[email protected]>
Date: Tue, 09 Aug 2005 09:56:50 +0200
Kay-Uwe Kasemir wrote:
Hi:
I think Ralph's recent answer with regard to the gateway already shows
that we can _not_ support all data types native to the machine
on which the client is run.
We have to agree on a limited set of types
because the gateway must understand all types
in order to compare the values against deadbands etc.
I'm happy to repeat once more:
There are _two_ type spaces [or whatever term is appropriate] connected to this issue, which are _separate_.
1. One type space contains the fixed set of native "server-side" types that Data Access is going to support when transporting stuff - across language and machine borders. We have to define this type space, together with a clever implementation of a type designator, that should be comprehensive and easy-to-use. (Kay's further discussion is about this type space.)
2. The other type space contains some (probably a subset) of the Data Access implementation language's basic types. These are the types that a user application will use to store the data, so Data Access will use these types in the interfaces and will convert between the language and platform independent fixed types (last paragraph) to the types of the user's data (this paragraph).
It's not that difficult, is it?
Ralph
Re: Channel Access Client Interface Kay-Uwe Kasemir
Channel Access Client Interface Bob Dalesio
Prev: RE: Channel Access Client Interface Jeff Hill
Next: Re: Channel Access Client Interface Marty Kraimer
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Access Client Interface Kay-Uwe Kasemir
Next: Re: Channel Access Client Interface Kay-Uwe Kasemir
