On Aug 9, 2005, at 03:56, Ralph Lange wrote:
There are _two_ type spaces [or whatever term is appropriate]
connected to this issue, which are _separate_.
1. One type space contains the fixed set of native "server-side" types
that Data Access is going to support when transporting stuff - across
language and machine borders. We have to define this type space,
together with a clever implementation of a type designator, that
should be comprehensive and easy-to-use. (Kay's further discussion is
about this type space.)
2. The other type space contains some (probably a subset) of the Data
Access implementation language's basic types. These are the types that
a user application will use to store the data, so Data Access will use
these types in the interfaces and will convert between the language
and platform independent fixed types (last paragraph) to the types of
the user's data (this paragraph).
It's not that difficult, is it?
I think that's what I'm presenting on:
http://www.aps.anl.gov/epics/wiki/index.php/V4_Data_Interface
The available data types are fixed & limited:
The DataDescriptor interface will tell the user that it's an
Integer with 16, 32, 64 bits,
a Real with 32 and 64 bits, ...
You can get the exact type, for example a real64_t,
but there's also room for 'convenience' routines
that provide 'double' or 'int', the basic types of the
language where the exact type isn't nailed down.
I'm also happy to repeat once more ;-) :
Do you (and Ben) think that an interface like the DataDescriptor
with getType(), getBitsize(), .. would work?
Or is it necessary to get a
struct { Type type, int bitsize, ... }
as you suggested earlier?
As for actually getting the data, one group proposes data access
pretty much as it is.
Marty suggested one interface per data type: NaInt16, NaInt32, ...
That's similar to the current Java channel access.
I find it inconvenient, because a lot of user code ends up looking like
this:
double d;
if (data.getType() == ...int16...)
d = (double) ((NaInt16)data.getInterface()).get();
else if (data.getType() == ...int32...)
d = (double) ((NaInt32)data.getInterface()).get();
So if one goes with a 'reader' interface, I'd prefer the
DataReader on
http://www.aps.anl.gov/epics/wiki/index.php/V4_Data_Interface:
/* try to get the value as double, regardless of native type */
double d;
if (reader->getDouble(d)) { /* OK */ } else { /* doesn't convert to
double */ }
-Kay
- Re: Channel Access Client Interface Benjamin Franksen
- RE: Channel Access Client Interface Jeff Hill
- Channel Access Client Interface Bob Dalesio
- Re: Channel Access Client Interface Kay-Uwe Kasemir
- Re: Channel Access Client Interface Ralph Lange
RE: Channel Access Client Interface Dalesio, Leo `Bob`
Re: Channel Access Client Interface Marty Kraimer
<2005>
2025
2026
<2005>
2025
2026
