2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Channel Access Client Interface
To: [email protected]
Date: Thu, 11 Aug 2005 15:24:14 +0200
On Tuesday 09 August 2005 14:57, Kay-Uwe Kasemir wrote:
> Do you (and Ben) think that an interface like the DataDescriptor
> with getType(), getBitsize(), .. would work?
> Or is it necessary to get a
>    struct { Type type, int bitsize, ... }
> as you suggested earlier?
It may have advantages to use an abstract data type (for the type
descriptor) instead of a concrete one. However, it should be possible
for generic user code to store the type descriptor along with the data.
Your EpicsDataDescriptor is a pure interface. That means generic user
code must always retrieve all the information bit by bit and construct
its own variant of type descriptor, which I think is not very
convenient. I would recommend to use a non-virtual class, here, that
also contains copy-constructor and operator=, so that it can be passed
(and stored) by value.
Another point: I think that calling inappropriate methods of
EpicsDataDescriptor should throw an exception. For instance, calling
getNumDims() on a type descriptor that does not represent an array
throws an exception.
An alternative would be to use the visitor pattern. A C++ interface
could look like this (sketch):
class TypeDescriptor {
	void traverse(TypeDescriptorVisitor *visitor);
class TypeDescriptorVisitor {
    virtual void on_Octet();
    virtual void on_Bool();
    virtual void on_Integer(bool signed, unsigned bitSize);
    virtual void on_Floating(unsigned bitSize);
    virtual void on_String();
    virtual void on_Timestamp();
    virtual void on_Enum(unsigned count, EpicsString *names);
    virtual void on_Array(unsigned dimCount, unsigned *sizes,
TypeDescriptor &elemType);
    virtual void on_Structure(propertyCatalog &catalog);
    virtual void on_Any();
where the user code has to create an implementation of this interface
and give DataAccess a reference to an object of this class if it wants
type information.
In case you wonder what the on_Any() method is for: Note that the
methods in class TypeDescriptorVisitor are /not/ pure virtual. This is
because for convenient use they should have default definitions (i.e.
implementations in the base class). The default is to call on_Any and
the latter does nothing. Of course, you can override on_Any() to
provide another default.
Example: Testing whether a type is an integer
// user code:
struct IsInteger : public TypeDescriptorVisitor {
    bool isInteger;
    virtual void on_Any() { isInteger = false; }
    virtual void on_Integer(bool, unsigned) { isInteger = true; }
Ben
Channel Access Client Interface Bob Dalesio
Re: Channel Access Client Interface Ralph Lange
Re: Channel Access Client Interface Kay-Uwe Kasemir
Prev: Re: Channel Access Client Interface Ralph Lange
Next: RE: Channel Access Client Interface Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Channel Access Client Interface Kay-Uwe Kasemir
