2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Fwd: Moving event generator and event receiver record support out of base]
To: EPICS core-talk <[email protected]>
Date: Mon, 12 Sep 2005 11:16:30 -0500
Andrew Johnson wrote:
I agree with Dayle that we should remove these records from base, especially as they're already unbundled into modules/timing/apsEvent, but I'm not 100% convinced we should do it in the middle of a major release number - any comments either way from the floor?
- Andrew
-------- Original Message --------
Subject: Moving event generator and event receiver record support out of base
Date: Fri, 09 Sep 2005 17:09:49 -0700 (PDT)
Hi Andrew,
Can I put in a vote to pull er*Record and eg*Record support from base/src/rec
in the next release? It's hardware support and doesn't belong with soft
ioc records. It's better in the site packages evg and evr.
Dayle
The device and driver support has already been removed from base for the next 3.14 release. This means that applications that use the APS event system already have to make some changes. This let them also get egRecord, egeventRecord, erRecord, and ereventRecord from modules/timing/apsEvent.
As I recall at least some of these were modified for the SLS and later event systems.
Marty
Re: [Fwd: Moving event generator and event receiver record support out of base] Andrew Johnson
Prev: [Fwd: Moving event generator and event receiver record support out of base] Andrew Johnson
Next: Re: [Fwd: Moving event generator and event receiver record support out of base] Andrew Johnson
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
