Does the SLS event system support make use of the er* and eg* record
types from Base, or do they have their own record types? If APS is the
only site actually using these records then we should definately remove
them, but if sites using the SLS event boards rely on the record types
then they probably should remain. Timo, would you like to comment on
Dayle's suggestion?
- Andrew
Marty Kraimer wrote:
Andrew Johnson wrote:
I agree with Dayle that we should remove these records from base,
especially as they're already unbundled into modules/timing/apsEvent,
but I'm not 100% convinced we should do it in the middle of a major
release number - any comments either way from the floor?
- Andrew
-------- Original Message --------
Subject: Moving event generator and event receiver record support out
of base
Date: Fri, 09 Sep 2005 17:09:49 -0700 (PDT)
To: Andrew Johnson <[email protected]>
Hi Andrew,
Can I put in a vote to pull er*Record and eg*Record support from
base/src/rec
in the next release? It's hardware support and doesn't belong with soft
ioc records. It's better in the site packages evg and evr.
Dayle
The device and driver support has already been removed from base for the
next 3.14 release.
This means that applications that use the APS event system already have
to make some changes.
This let them also get egRecord, egeventRecord, erRecord, and
ereventRecord from modules/timing/apsEvent.
As I recall at least some of these were modified for the SLS and later
event systems.
Marty
English probably arose from Normans trying to pick up Saxon girls.
- Re: [Fwd: Moving event generator and event receiver record support out of base] Dayle Kotturi
- Re: [Fwd: Moving event generator and event receiver record support out of base] Korhonen Timo
- [Fwd: Moving event generator and event receiver record support out of base] Andrew Johnson
- Re: [Fwd: Moving event generator and event receiver record support out of base] Marty Kraimer
Re: Data Interface Classes Kay-Uwe Kasemir
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
