2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: [Fwd: Moving event generator and event receiver record support out of base]
Cc: Marty Kraimer <[email protected]>, EPICS core-talk <[email protected]>, Dayle Kotturi <[email protected]>
Date: Tue, 13 Sep 2005 09:01:29 +0200
Hi Andrew and all,
Andrew Johnson wrote:
Does the SLS event system support make use of the er* and eg* record types from Base, or do they have their own record types? If APS is the only site actually using these records then we should definately remove them, but if sites using the SLS event boards rely on the record types then they probably should remain. Timo, would you like to comment on Dayle's suggestion?
There are four record types (at the moment) that are related to the event system (APS & derivatives): eg, egevent, er, erevent. For the SLS event system the er and eg record have been quite radically extended; with the Diamond system even more. The e*eventRecords are (or better said, could be) used unmodified from the base. But I would agree (and strongly prefer) them to be removed from the base and having them in a separate package as Dayle suggested. They are closely bound to the hardware and have no use outside the event system.
That implies however that we have to take care of packaging the things properly. We probably will need different packages for the different hardware generations.
best regards,
Timo
- Andrew
I agree with Dayle that we should remove these records from base, especially as they're already unbundled into modules/timing/apsEvent, but I'm not 100% convinced we should do it in the middle of a major release number - any comments either way from the floor?
- Andrew
-------- Original Message --------
Subject: Moving event generator and event receiver record support out of base
Date: Fri, 09 Sep 2005 17:09:49 -0700 (PDT)
Hi Andrew,
Can I put in a vote to pull er*Record and eg*Record support from base/src/rec
in the next release? It's hardware support and doesn't belong with soft
ioc records. It's better in the site packages evg and evr.
Dayle
The device and driver support has already been removed from base for the next 3.14 release. This means that applications that use the APS event system already have to make some changes. This let them also get egRecord, egeventRecord, erRecord, and ereventRecord from modules/timing/apsEvent.
As I recall at least some of these were modified for the SLS and later event systems.
Marty
Timo Korhonen  PSI (Paul Scherrer Institut)
               CH-5232 Villigen PSI
               tel + 41- 56 3103262  fax + 41 - 56 310 3383
e-mail:	       [email protected]
[Fwd: Moving event generator and event receiver record support out of base] Andrew Johnson
Re: [Fwd: Moving event generator and event receiver record support out of base] Marty Kraimer
Re: [Fwd: Moving event generator and event receiver record support out of base] Andrew Johnson
Prev: Re: [Fwd: Moving event generator and event receiver record support out of base] Dayle Kotturi
Next: Re: Data Access Name Clash Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: [Fwd: Moving event generator and event receiver record support out of base] Marty Kraimer
Next: Data Access / status of CVS repository Ralph Lange
