2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: data access structures, strings
To: Jeff Hill <[email protected]>
Cc: [email protected]
Date: Mon, 26 Sep 2005 17:34:15 -0400
On Sep 26, 2005, at 14:12 , Jeff Hill wrote:
1) In your example you know at compile time that you want to extract the
red, green, and blue properties out of some unknown PropertyCatalog.
Almost. I want the r, g, b under "color":
 catalog->color->red, ...
Who knows, the catalog might also contain
 catalog->preferred_display->foreground->color->red
 catalog->preferred_display->background->color->red
 catalog->beam->color->red
but I don't want any of those reds.
In your example, you expose a "red" property and
receive a "red" from the "incoming".
Which one would that be?
In this situation you have control over the content of MyColor and no
control over the content of catalogX. Since you have control over MyColor
you can access it in any way MyColor sees fit - with blinding speed.
struct MyColor
public:
    void set ( const & PropertyCatalog );
private:
    int r, g, b;
    template < class VIEWER >
    static void traverse ( VIEWER & );
MyColor :: set ( const PropertyCatalog & incoming )
    ClassCatalog
        < MyColor, PropertyManipulator, traverse >
        manipulator ( *this );
    manipulator = incoming;
inline void MyColor :: traverse ( VIEWER & viewer )
    viewer.reveal ( colorRed, & MyColor::r );
    viewer.reveal ( colorGreen, & MyColor::g );
    viewer.reveal ( colorBlue, & MyColor::b );
...C++ templates are great for situations where the algorithm Is the same, but the data type varies. I can show you how to automate this if you are interested
I'm purposedly avoiding the "locator" and templates at this stage
in order to see all that's happening.
When do you think the stringSegment will be usable?
It's the mayor thing missing to be able to play
with some more meaningful data.
Personally, the
getDouble()/getFloat/getInt/getUnsigned/getTime/getString/... type of
interface makes me nauseous.
Well, if we want to get down to what we're feeling,
I worry about the bend-over-and-expose-your-data approach.
That's almost a "paradigm".
-Kay
Re: data access structures, strings Andrew Johnson
RE: data access structures, strings Jeff Hill
Prev: RE: data access structures, strings Jeff Hill
Next: RE: data access structures, strings Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: data access structures, strings Andrew Johnson
