2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: data access structures, strings
To: Kay-Uwe Kasemir <[email protected]>
Cc: Jeff Hill <[email protected]>, [email protected]
Date: Mon, 26 Sep 2005 18:07:42 -0500
Kay-Uwe Kasemir wrote:
When do you think the stringSegment will be usable?
I'm hoping Jeff will replace his stringSegment in dataAccess with the string API that I've been working on. These are the current base classes; there will non-member non-friend functions for doing numeric conversions, and other convenience functions like operator==:
 class StringReader {
 public:
     // String length
     virtual size_t size() const = 0;
     // Comparison functions
     virtual bool equals(const StringReader & rhs) const = 0;
     virtual bool contains(const StringReader & rhs, size_t pos) const = 0;
virtual bool contains(const char *str, size_t len, size_t pos = 0) const = 0;
     // Individual character access
     virtual char operator[] (size_t pos) const = 0;
     // Copy out to buffer, no terminator
virtual size_t extract(char *buf, size_t cap, size_t pos = 0) const = 0;
 class StringEditor :
     public StringReader {
 public:
     // Length adjustment
     virtual void resize(size_t len, char fill = '\0') = 0;
     // Buffer storage management
     virtual size_t capacity() const = 0;
     virtual void reserve(size_t cap) = 0;
     // Assignment
     virtual void assign(const StringReader & src, size_t pos = 0) = 0;
     virtual void assign(const char *str, size_t len) = 0;
     // Append
     virtual void append(char chr) = 0;
     virtual void append(const StringReader & src, size_t pos = 0) = 0;
     virtual void append(const char *str, size_t len) = 0;
     // Overloaded operators
     StringEditor& operator = (const StringReader &rhs);
     StringEditor& operator = (const char *rhs);
     StringEditor& operator += (char chr);
     StringEditor& operator += (const StringReader &rhs);
     StringEditor& operator += (const char *rhs);
I have three tested concrete implementations which use contiguous buffers:
ConstString : Concrete implementation of StringReader for wrapping "string literals" and other const char* buffers.
FixedString<int> : Template implementation of StringEditor, using a fixed size buffer which is a class data member (no new/delete). The size is set at compile time by the template parameter, so this is a safe version of a regular char[] buffer.
VariableString : Implementation of StringEditor, using new[] and delete[] to provide a contiguous buffer which increases in size as needed by multiples of 2.
All the above implementations maintain a hidden \0 terminator byte after the end of the string data, and also provide a c_str() function (not part of the base class interface) for compatibility with C functions. If you created the string, you get to look inside the box; if you're given a StringReader or even a StringEditor you don't, and you'll have to copy it to pass it to printf().
I am also working on another implementation using multiple fixed size buffer segments that are allocated from and returned to a freelist. This is the implementation I'm hoping we'll use in the IOC database for string fields as it solves the memory fragmentation problem.
Comments and questions on the above are welcome.
- Andrew
English probably arose from Normans trying to pick up Saxon girls.
RE: data access structures, strings Jeff Hill
Re: data access structures, strings Kay-Uwe Kasemir
Prev: RE: data access structures, strings Jeff Hill
Next: RE: data access structures, strings Jeff Hill
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: data access structures, strings Kay-Uwe Kasemir
