Hello Andrew:
I like your approach very much.
It's unfortunate that your reader/write is of course
similar to std::string, MFC::CStr, ... and yet
we can't use any of the existing but have to make
our own again, but I guess that's just the way it is.
C++ just doesn't live up to any of the
sharing-of-code dreams.
On Sep 26, 2005, at 19:07 , Andrew Johnson wrote:
I'm hoping Jeff will replace his stringSegment in dataAccess with
the string API that I've been working on. These are the current
base classes; there will non-member non-friend functions for doing
numeric conversions, and other convenience functions like operator==:
I think we should be careful with
all C++ specialties like operators, templates,
multiple inheritance, Meyer's rules #1-99.
When EPICS started, there was C.
Now there's C++, but more and more people agree
that's a bad idea. So they use Java whenever possible.
Yet that's somewhat of a sandbox language which can't be used
for e.g. device drivers.
In a few more years there will be another language.
Today, however, I have to acknowledge that C++ is the only
practical language for implementing V4.
But the APIs for strings, data access, ... could still
be kept basic enough that SWIG can translate the C++
header files into perl bindings,
a perl script could turn the C++ into objective C,
and the C++ and Java implementations also match.
Meaning:
Use 'assign' instead of 'operator =',
'isEqual' instead of 'operator ==',
'getElement' instead of 'operator []', ...
After replacing all operators, I think your suggestion is great.
-Kay
class StringReader {
public:
// String length
virtual size_t size() const = 0;
// Comparison functions
virtual bool equals(const StringReader & rhs) const = 0;
virtual bool contains(const StringReader & rhs, size_t pos)
const = 0;
virtual bool contains(const char *str, size_t len, size_t pos
= 0) const = 0;
// Individual character access
virtual char operator[] (size_t pos) const = 0;
// Copy out to buffer, no terminator
virtual size_t extract(char *buf, size_t cap, size_t pos = 0)
const = 0;
class StringEditor :
public StringReader {
public:
// Length adjustment
virtual void resize(size_t len, char fill = '\0') = 0;
// Buffer storage management
virtual size_t capacity() const = 0;
virtual void reserve(size_t cap) = 0;
// Assignment
virtual void assign(const StringReader & src, size_t pos = 0)
= 0;
virtual void assign(const char *str, size_t len) = 0;
// Append
virtual void append(char chr) = 0;
virtual void append(const StringReader & src, size_t pos = 0)
= 0;
virtual void append(const char *str, size_t len) = 0;
// Overloaded operators
StringEditor& operator = (const StringReader &rhs);
StringEditor& operator = (const char *rhs);
StringEditor& operator += (char chr);
StringEditor& operator += (const StringReader &rhs);
StringEditor& operator += (const char *rhs);
I have three tested concrete implementations which use contiguous
buffers:
ConstString : Concrete implementation of StringReader for wrapping
"string literals" and other const char* buffers.
FixedString<int> : Template implementation of StringEditor, using a
fixed size buffer which is a class data member (no new/delete).
The size is set at compile time by the template parameter, so this
is a safe version of a regular char[] buffer.
VariableString : Implementation of StringEditor, using new[] and
delete[] to provide a contiguous buffer which increases in size as
needed by multiples of 2.
All the above implementations maintain a hidden \0 terminator byte
after the end of the string data, and also provide a c_str()
function (not part of the base class interface) for compatibility
with C functions. If you created the string, you get to look inside
the box; if you're given a StringReader or even a StringEditor you
don't, and you'll have to copy it to pass it to printf().
I am also working on another implementation using multiple fixed
size buffer segments that are allocated from and returned to a
freelist. This is the implementation I'm hoping we'll use in the
IOC database for string fields as it solves the memory
fragmentation problem.
Comments and questions on the above are welcome.
- Andrew
English probably arose from Normans trying to pick up Saxon girls.
- RE: data access structures, strings Jeff Hill
- Re: data access structures, strings Andrew Johnson
- Re: data access structures, strings Marty Kraimer
- Re: data access structures, strings Kay-Uwe Kasemir
<2005>
2025
2026
<2005>
2025
2026
