Hi:
On Oct 17, 2005, at 11:57 , Marty Kraimer wrote:
2) It is not in the slides but at the presentation Mark said that
it is easy to allow ACS to talk to epics but hard to have epics
talk to ACS. I will go further and say that it will be hard to make
any wide interface talk to another wide interface unless they are
very similar. A strength of EPICS is that other systems can talk to
it.
Yes, EPICS is easier to interface than other middlewares
since it's only a flat list of properties that one
can read and sometimes write.
TANGO, ACS distinguish between commands and properties,
even commands, static properties and attributes that change at runtime.
1) The IOC database is the heart of EPICS iocCore. It is what
distinguishes EPICS from the other control systems in use by the
accelerator and telescope control systems. Most of the others have
the concept of device servers in the front ends rather that an
intelligent runtime database, which means that the intelligence
resides in the workstations or else is implement in an ad-hoc way
in the device servers or in some other systems like PLCs.
2) The interface to the IOC database is narrow in the sense that
communication is done via data rather than a large set of objects.
This is what allows general purpose tools like display managers and
what makes it easy for other systems to talk to IOCs. In EPICS
facilities it is common for operators to create displays for MEDM
or EDM. I suspect that tools like the the tango gui builder would
be used by programmers rather than operators or hardware oriented
engineers. Thus we must be carefull about how much device
orientation we introduce into IOCs. Perhaps a power supply but not
a high level physics abstraction.
Isn't it strange that on one hand we have an intelligent database,
but only a flat channels-with-properties interface to it?
Our display tools only read & write values from/to properties.
MEDM doesn't know that writing to the 'jog' fields of a motor
record actually issues a command, while writing to the
max. velocity field changes something that should probably
be stored for bumpless reboot.
V4 won't change this. Should it?
It it sufficient for redundancy to simply mirror the values
of records' fields, or is it necessary to know a bit more
about what the fields do, i.e. start a command?
-Kay
- ICALEPCS and EPICS iocCore V4 Marty Kraimer
Re: ICALEPCS and EPICS iocCore V4 Steve Lewis
<2005>
2025
2026
<2005>
2025
2026
