Marty, thanks for your extremely insightful summary of 5
meetings...although I missed seeing all of you and everyone else in
person, I feel like you have pulled it together better than I would
if I had actually been there :-)
<RANT>
At 10:57 AM -0500 2005/10/17, Marty Kraimer wrote:
There are two things I want to emphasize.
1) EPICS has a narrow interface and ALAMA/ACS has a wide interface.
Narrow means that EPICS just has well defined data types and wide
means that ACS has object to object communication.
This is the key difference. The NIF control system also has an
ALMA_like, wide, object-to-object interface. My opinion is that this
nearly killed it. A wide interface is a very subtle way of replacing
the benefits of encapsulation and data hiding with (larger) problem
of "interface coupling".
You cannot effectively build tools; programmers need to be involved
at every level, forever. Even small changes require rebuilding
everything: it's "make clean; make" every night--hopefully you have a
full suite of regression tests with a lab filled with real hardware.
NIF has about $500K sunk in such a lab, and keeps its test team
staffed at 25% of the level of the developers.
DON'T DO THIS.
The following are the main features of EPICS IOCs
1) The IOC database is the heart of EPICS iocCore. It is what
distinguishes EPICS from the other control systems in use by the
accelerator and telescope control systems. Most of the others have
the concept of device servers in the front ends rather that an
intelligent runtime database, which means that the intelligence
resides in the workstations or else is implement in an ad-hoc way in
the device servers or in some other systems like PLCs.
YES, YES, YES. Repeat this every morning when you wake up; and every
evening before you go to sleep.
2) The interface to the IOC database is narrow in the sense that
communication is done via data rather than a large set of objects.
This is what allows general purpose tools like display managers and
what makes it easy for other systems to talk to IOCs. In EPICS
facilities it is common for operators to create displays for MEDM or
EDM. I suspect that tools like the the tango gui builder would be
used by programmers rather than operators or hardware oriented
engineers. Thus we must be carefull about how much device
orientation we introduce into IOCs. Perhaps a power supply but not a
high level physics abstraction.
Again, this is what the NIF architecture is like. It is (was)
extremely frustrating under this architecture to bring some
functionality to bear on the hardware and to the operators. What
would have taken 10 minutes with VDCT and 1 minute with MEDM in EPICS
took from 1 hour to 1 day from each of 1) the FEP programmer; 2) the
tier 2 programmer; 3) the IDL/SQL/RDB team; 4) the GUI programmer; 5)
the tier 3 team [sequencer-like "scripts"]; 6) the CM team to
"regenerate the IDL", do "make clean; make". And then you test.
Elapsed calendar time: weeks to months.
We called it "IDL hell" and employed the most devious strategies to
avoid items (2)-(6).
</RANT>
- Re: ICALEPCS and EPICS iocCore V4 Kay-Uwe Kasemir
- Re: ICALEPCS and EPICS iocCore V4 Claude Saunders
- ICALEPCS and EPICS iocCore V4 Marty Kraimer
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
