Steve Lewis wrote:
Marty Kraimer wrote:
2) The interface to the IOC database is narrow in the sense that
communication is done via data rather than a large set of objects.
This is what allows general purpose tools like display managers and
what makes it easy for other systems to talk to IOCs. In EPICS
facilities it is common for operators to create displays for MEDM or
EDM. I suspect that tools like the the tango gui builder would be
used by programmers rather than operators or hardware oriented
engineers. Thus we must be carefull about how much device orientation
we introduce into IOCs. Perhaps a power supply but not a high level
physics abstraction.
Again, this is what the NIF architecture is like. It is (was)
extremely frustrating under this architecture to bring some
functionality to bear on the hardware and to the operators. What
would have taken 10 minutes with VDCT and 1 minute with MEDM in EPICS
took from 1 hour to 1 day from each of 1) the FEP programmer; 2) the
tier 2 programmer; 3) the IDL/SQL/RDB team; 4) the GUI programmer; 5)
the tier 3 team [sequencer-like "scripts"]; 6) the CM team to
"regenerate the IDL", do "make clean; make". And then you test.
Elapsed calendar time: weeks to months.
We called it "IDL hell" and employed the most devious strategies to
avoid items (2)-(6).
</RANT>
There was at one time a middle ground here, and it was called CDEV. I'm
not suggesting reviving that particular implementation, but it was a
interesting idea, and there was a great deal of thought and design that
went into it. There are quite a few similarities between the old CDEV
discussions, and what I'm hearing now about the tension between
channel-based and object-based access.
CDEV provided a device abstraction (sort of like objects with a dynamic
invocation interface) while being readily re-configured. In short, no
"make clean; make", or IDL hell. So...
Is there anything wrong with supporting 2 namespaces for control? One
would be the channel-based namespace EPICS currently offers, and the
other would be a device abstraction ala CDEV. Before everyone recoils in
horror, realize that most places wind up de-facto doing this anyways.
SNS has EPICS, but yet all their applications are driven via an object
model realized in a relational database, that in turn has the
association with the underlying EPICS PVs. Here at APS, our OAG group is
effectively doing a form of this using SDDS to group PVs into more
useful abstractions. All this to make higher level operations and
physics applications easier to understand and work with.
So keep the nimble applications like MEDM, which require a channel-based
data layer, but explicitly support a device abstraction layer as well.
Things like feedback loops would be left to the EPICS record level, not
implemented at the device abstraction layer.
I guess this isn't too far from just dropping the upper levels of Tango
on top of EPICS, but it is distinct from that approach in that I would
suggest making it more configurable than the typical IDL based approach
(which Steve correctly notes can be hell in a dynamic environment).
These dynamic device abstractions could be presented as CORBA objects in
an ORB possibly...
<disclaimer>
Just talking out loud here, and please forgive me if I have
misrepresented CDEV, Tango, or EPICS.
</disclaimer>
- Claude
- RE: ICALEPCS and EPICS iocCore V4 Jeff Hill
- ICALEPCS and EPICS iocCore V4 Marty Kraimer
- Re: ICALEPCS and EPICS iocCore V4 Steve Lewis
Re: ICALEPCS and EPICS iocCore V4 Kay-Uwe Kasemir
<2005>
2025
2026
Re: ICALEPCS and EPICS iocCore V4 Benjamin Franksen
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
