2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: ICALEPCS and EPICS iocCore V4
To: <[email protected]>
Date: Mon, 17 Oct 2005 12:59:20 -0700
At 1:23 PM -0600 2005/10/17, Jeff Hill wrote:
Proper uniform definition of connection responsiveness notification
interfaces is also a very important issue that is often overlooked in a
first cut CORBA based approach. In any case that was what the reviewers
commented about initial efforts at NIF.
I was one of those early reviewers. Although we did not see the full negative implications and coupling of the wide, early-binding interfaces, we did notice the fundamentally synchronous nature of the CORBA in use (again, the available vendors did not support the event system and some other CORBA features).
Much was done (by the vendors and the NIF developers) to mitigate this, but when either a tier-1 or tier-2 program dies, often it is not possible to smoothly re-insert it into the mesh of still running programs in all 3 tiers. There are also messages queued up deep in the (opaque) CORBA and TCP/IP layers that "assault" a newly restarted IOC and can cause it to fail again. Often the only recourse is to tear down a substantial block of tier-1, -2, and -3 programs and restart them in a benign order.
A non-solution is the practice of storing the dynamic connection information (CORBA references) back in the RDB: after a really nasty crash, the RDB has to be (manually) scrubbed, since no starting order works. This might have implications for a central nameserver in a 3-tier EPICS system--unless you think there will be no "nasty crashes" ever :-)
Re: ICALEPCS and EPICS iocCore V4 Claude Saunders
RE: ICALEPCS and EPICS iocCore V4 Jeff Hill
Prev: Re: ICALEPCS and EPICS iocCore V4 Steve Lewis
Next: Re: ICALEPCS and EPICS iocCore V4 Claude Saunders
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: ICALEPCS and EPICS iocCore V4 Jeff Hill
