2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: ICALEPCS and EPICS iocCore V4
To: [email protected]
Date: Mon, 17 Oct 2005 12:40:29 -0700
At 2:14 PM -0400 2005/10/17, Kay-Uwe Kasemir wrote:
But back to the technical aspect, did NIF just pick the wrong
interfaces and thus each change requires 2-6?
Is the other OO framework talk mostly by people who
have never actually tried it on the scale of NIF?
Well, there are several aspects here. Because of the need for Ada language bindings, there were few choices of CORBA vendors; none offered Dynamic Invocation Interface. So a change of interface is a very early binding.
There was one Java program that could access tier-1 (IOC) interfaces as well as tier-2; when started at the command line, it dynamically parsed *ALL* the IDL in the shop. You were then presented with a pick list of 300-400 callable interfaces: you filled in the IN parameters and back came the OUTs. (It took about 15 minutes to start on a Sunblade 1000.)
The problem was that each object designer created whatever interfaces they saw fit to support use cases as they came along. So in addition to the "interesting" ones (like commands), every get/set for every attribute required a semi-custom interface. What took the place of the motor record, for example, had about 50 interfaces...
So the interfaces were not "wrong", but in a model where one requirement -> one interface, then new interfaces (commands + attributes) are an ongoing reality.
Adding new attributes to the motor record affects only a sophisticated sequencers, say, that need to manipulate them; it does not affect displays, archivers, alarm handlers, striptool, etc, etc, as long as the list of channels is administratively dealt with properly, as Kay suggests. That's very late binding.
ICALEPCS and EPICS iocCore V4 Marty Kraimer
Re: ICALEPCS and EPICS iocCore V4 Steve Lewis
Re: ICALEPCS and EPICS iocCore V4 Kay-Uwe Kasemir
Prev: RE: ICALEPCS and EPICS iocCore V4 Jeff Hill
Next: RE: ICALEPCS and EPICS iocCore V4 Steve Lewis
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: ICALEPCS and EPICS iocCore V4 Kay-Uwe Kasemir
Next: Re: ICALEPCS and EPICS iocCore V4 Benjamin Franksen
