Marty Kraimer wrote:
Are you saying that we should not implement block, process, and wait
semantics as part of a link definition?
I am under the impression that the general concensus that it is a good
idea and we were deciding semantics.
Am I wrong?
I'm *not* against providing control over synchronization and sequencing
of links, especially when it comes to arrays of them, but I don't
believe all of the "block, process and wait" attributes make sense when
you're dealing with single links, especially when it comes to fields
like SDIS and TSEL.
Now I'm probably only complaining about some aspects of block and wait
here, since process obviously *is* a link attribute for the caPut/caGet
link types. I also accept that we need the ability to control whether
get/put operations on individual links cause the source record to wait
for the target operation to complete. However the descriptions I've
seen so far of what the "block, process and wait" attributes mean
haven't been very clear.
I suspect that the process attribute of a caMonitor link type actually
has a different meaning to that of a caGet (for caMonitor it controls
processing of the source record when a monitor event occurs, not the
processing of the target record) - am I right in that? If so, I would
really want to use a different name for it, something like updateScan?
I *am* saying that the complex sequencing and synchronization controls
should not be part of the basic link type itself, but are more logically
part of the array of links that the calc and sequence records etc.
actually implement. Instead of using an array of links, they could
contains an array of structures, where each structure contains a link
field plus some other fields that control the seq/sync controls for that
link. This would allow the sequence record to have even more complex
controls than calc, since it wants to allow the user to sequence input
and output links together in groups maybe, insert delays and so on.
I'd also like to see the discussion of the capabilities of individual
link types distinguished from that of the capabilities of the generic
link interface. A process attribute controls a capability of CA and DB
links, but means nothing to my xyzzy link type, so please don't make my
link have to implement stuff it doesn't need.
- Andrew
English probably arose from Normans trying to pick up Saxon girls.
- [Fwd: Re: Link arrays / syntax] Marty Kraimer
- Re: [Fwd: Re: Link arrays / syntax] Benjamin Franksen
- Re: [Fwd: Re: Link arrays / syntax] Marty Kraimer
- Re: Link arrays / syntax Ralph Lange
- Re: Link arrays / syntax Marty Kraimer
- Re: Link arrays / syntax Steve Lewis
- Re: Link arrays / syntax Tim Mooney
- Re: Link arrays / syntax Andrew Johnson
Re: alarm/severity Ralph Lange
Re: alarm/severity Kay-Uwe Kasemir
<2005>
2025
2026
<2005>
2025
2026
ANJ, 02 Feb 2012 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
