2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Requirements? Re: alarm/severity
To: [email protected]
Date: Fri, 21 Oct 2005 09:38:29 -0400
On Oct 20, 2005, at 18:01 , Andrew Johnson wrote:
* update on change in value
 with relative and absolute deadbands,
 each as a positive and negative limit.
 E.g. update when value increases by >= 1% or descreases by <=0.5%.
 EPICS V3 only has a single absolute deadband.
* update on archive related changes
 which are designated relative and absolute deadbands,
 again pos. & neg.,
 and in addition a minimum update rate.
 EPICS V3 only ADEL, no additional periodic update.
"Designated" by who? In V3 the ADEL and MDEL fields allows the DB designer to set appropriate per-record deadbands; just allowing every client to set its own deadband in the subscription request doesn't provide any way for the DB designer to even hint what an appropriate deadband might be, which could signficantly impact IOC performance. Maybe that information doesn't belong in the database at all, but I'm not convinced of that; I don't think we have all the requirements for V4 deadbands specified yet.
What the requirements are is of course a fundamental question
and part of our current dilemma.
If we consider support for other systems like Tango a requirement,
then update rates and deadbands can be designated by each client.
Bob's "V4 Functional Specifications" presentation from the SLAC
EPICS meeting also included
"V4 Data Acquisition Capabilities: New subscription parameters:
rate limit, value changes (as before but also % change)".
So from that I'd conclude:
V4 and Tango support both require
deadbands for 'on change' updates designated by the subscribing client.
You're follow-up concerns are all valid,
but they are implementation details to be determined
once we know if per-client deadbands & rates are requirements.
As far as I understand, the outcome of the Archamps meeting is
that there's very little management support for V4 development
because of the impression that we've been designing pieces of
a neat implementation, but without sufficient agreement amongst
the developers and more important without requirements from customers.
So more than one 'plug' has been pulled and we're back to
use cases, then a 'client' API design from Cosylab, ...
-Kay
alarm/severity Kay-Uwe Kasemir
Re: alarm/severity Ralph Lange
Re: alarm/severity Kay-Uwe Kasemir
Re: alarm/severity Andrew Johnson
Prev: Re: [Fwd: Re: Link arrays / syntax] Benjamin Franksen
Next: Re: alarm/severity Kay-Uwe Kasemir
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: alarm/severity Andrew Johnson
Next: Record Processing Marty Kraimer
