On Wed, 2005-11-02 at 06:30 -0600, Marty Kraimer wrote:
> Ernest L. Williams Jr. wrote:
> >On Tue, 2005-11-01 at 13:26 -0600, Marty Kraimer wrote:
> >>I did a cvs update and rebuild.
> >>exampleApp still crashes.
> >>There are still lots of warning messages like
> >>/fdmgr/fdmgr.cpp
> >>"../../../src/libCom/fdmgr/fdManager.h", line 171: Warning: Conversion
> >>of 64 bit type value to "const unsigned" causes truncation.
> >>"../../../src/libCom/fdmgr/fdmgr.cpp", line 33: Warning: Conversion of
> >>I think we should create 3.14.8 and take care of this later.
> >>I am concerned that fixing the 64 bit problems will in turn cause new bugs.
> >Marty, I am not seeing this issue on linux AMD64. Is this happening on
> >Solaris 64-bit?
> Yes. It does not happen when I build with
> EPICS_HOST_ARCH=solaris-sparc64
Hmmm.
For linux64 the default for the GCC compiler is 64-bits. However, if
you want to build a 32-bit application on a 64 bit machine; you use must
add the "-m32" flag to GCC. I am going for the native 64-bit mode on
linux64. Although, I will have to live with some 32-bit apps on the
machine such as the vxWorks cross-compiler.
> Marty
- RE: R3.14.8 testing Jeff Hill
- Re: R3.14.8 testing Marty Kraimer
- Re: R3.14.8 testing Ernest L. Williams Jr.
FW: R3.14.8 testing Jeff Hill
<2005>
2025
2026
<2005>
2025
2026
