2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: R3.14.8 Status/logClient patch
To: [email protected]
Date: Wed, 16 Nov 2005 14:03:56 +0100
On Tuesday 15 November 2005 20:18, Andrew Johnson wrote:
> It would be nice to get Banjamin's patch to the logClient library
> included, which we're expecting tomorrow.
Small problem, here. Some explanation(s) first: The current module named
'logClient' contains two kinds of routines: generic (logClient*) and
specific (iocLog*, for the standard IOC error logging i.e. via
errlogAddListener). The latter stuff is only a very thin layer that
actually uses only the public interface of the generic routines.
However, teh separatioon is not complete; there are still a few places
where the generic routines do specific things:
(1) logClientSendMessage() checks the value of iocLogDisable and returns
without doing anything if it is set.
(2) logClientInit() uses the EPICS_IOC_LOG_* environment vars to
identify server address and port.
(3) logClientInit() also contains a call to errlogAddListener, so that
for all calls to errlog* a message is sent via the created logClient
instance.
These things do not belong to the generic functionality and instead
should be done by the special instance, namely the standard ioc (error)
logging client and its supporting routines.
OTOH, for strict compatibility, the behavior must remain exactly the
same as before, which means that instead of changing the existing
functions logClientSendMessage() and logClientInit(), I must add new
additional versions of them.
What should I do?
Note: The generic routines are not yet documented anywhere.
Does anyone actually use them, relying on the above behavior?
Ben
Re: R3.14.8 Status/logClient patch Benjamin Franksen
R3.14.8 Status Andrew Johnson
Prev: RE: R3.14.8 Status Denison, PN (Peter)
Next: Re: R3.14.8 Status Ralph Lange
Index: 2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: R3.14.8 Status/logClient patch Benjamin Franksen
