2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Build system problem (was: mrkSoftTest doesn't compile)
To: EPICS Core Talk <[email protected]>
Date: Wed, 16 Nov 2005 17:11:19 +0100
The two -Wl options (compiled-in locations for shared libraries) are correct: One location is the generic location, where the EPICS Base will be installed. The other is the local directory, i.e. the location of the Base that I'm currently linking against. This makes sure that the libraries are found on the development machine as well as on the runtime system (where the Base will be installed at the generic location).
There is one major problem, though:
The library path for the current linker command (-L) is set to the generic location! That means, that even if I'm pointing my local configure/RELEASE to my base under test (/home/unix/lange/work/epics/APS/epics/base/3-14-X), any executables will be linked against the generic libraries in the .../3-14-7-0 location, which are the old ones.
I assume that - while keeping both locations in the -Wl seems correct - the library path for the linker command should always be the location directly from the EPICS_BASE location set in configure/RELEASE
Janet, would you agree?
Ralph
Marty Kraimer wrote:
It works for me on my version of Linux. Mine, however, is getting old
uranus% cat /proc/version
Linux version 2.4.21-9.0.1.EL ([email protected]) (gcc version 3.2.3 20030502 (Red Hat Linux 3.2.3-26)) #1 Mon Feb 9 22:44:14 EST 2004
In
/usr/bin/g++ -o common -L/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86/ -Wl,-rpath,/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86 -Wl,-rpath,/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/linux-x86
Why are there two "-W1" pointing to different versions of base?
Marty
Ralph Lange wrote:
Marty,
mrkSoftTest doesn't compile aymore (neither on HP nor on Linux):
aCC -o access -L/opt/epics/R3.14.7/base/3-14-7-0/lib/hpux-parisc/ -AA -mt -Wl,+b/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/hpux-parisc:/home/unix/lange/work/epics/APS/epics/extensions/lib/hpux-parisc:/opt/epics/R3.14.7/base/3-14-7-0/lib/hpux-parisc,+s access_registerRecordDeviceDriver.o asinittest.o asTest.o asTrapWriteTest.o accessMain.o -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
/usr/ccs/bin/ld: Unsatisfied symbols:
pvar_int_dbRecordsOnceOnly (first referenced in access_registerRecordDeviceDriver.o) (data)
On Linux:
/usr/bin/g++ -o common -L/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86/ -Wl,-rpath,/opt/epics/R3.14.7/support/base/3-14-7-0/lib/linux-x86 -Wl,-rpath,/home/unix/lange/work/epics/APS/epics/base/3-14-X/lib/linux-x86 -Wl,-rpath,/home/unix/lange/work/epics/APS/epics/extensions/lib/linux-x86 devAiAsyn.o common_registerRecordDeviceDriver.o commonMain.o -ltestDevIoc -lrecIoc -lsoftDevIoc -liocsh -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom common_registerRecordDeviceDriver.o(.text+0x4a1): In function `__static_initialization_and_destruction_0': /net/unix/mnt/csr-home/lange/work/epics/APS/epics/mrkSoftTest/common/src/O.linux-x86/common_registerRecordDeviceDriver.cpp:264: undefined reference to `pvar_int_dbRecordsOnceOnly'
I don't see any changes in mrkSoftTest, though. Strange. I'm pretty sure you know faster than me what's wrong ...
Ralph
Re: Build system problem Andrew Johnson
mrkSoftTest doesn't compile Ralph Lange
Re: mrkSoftTest doesn't compile Marty Kraimer
Prev: RE: dbEvent.c line 665 Jeff Hill
Next: RE: dbEvent.c line 665 Jeff Hill
Index: 2002  2003  2004  <2005>  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: mrkSoftTest doesn't compile Marty Kraimer
Next: Re: Build system problem Andrew Johnson
